Silvester Posted June 28, 2012 Report Posted June 28, 2012 I ordered a new Carrier Bearing for my 620 and this time around it didn't include the center flange bolt... Where can i find this? Its the one that needs to be staked. The big one that goes right in the center. I think 18mm thickness and 1.5mm thread pattern. Quote
ggzilla Posted June 28, 2012 Report Posted June 28, 2012 Get it from Nissan, part number 32144-20401 Hex Nut. But it's almost $2.00. Quote
Silvester Posted June 29, 2012 Author Report Posted June 29, 2012 Removed it with the old decayed carrier bearing. It wasn't salvageable. Quote
Silvester Posted June 29, 2012 Author Report Posted June 29, 2012 You really helped me there, Gzilla. My local Nissan parts guy couldn't figure it out. just ordered it Quote
moparvwfreak Posted June 29, 2012 Report Posted June 29, 2012 I got 2 froom nissan when I fubared mine. Not to expencive either. Quote
Dawa Posted August 2, 2012 Report Posted August 2, 2012 i hope this bump (of an answered thread) grabs someone's attention is that the bolt that the 27mm nut goes on? if so.... my '73 620 fsm says the torque spec is 145+ ft/lb.... how the ef did you guys torque that thing? i dont have a vice nor that special nissan tool. also, im having problems removing the carrier bearing and insulator (trying to replace insulator) i dont have a press, any ideas? Quote
DanielC Posted August 2, 2012 Report Posted August 2, 2012 This is how I remove the flywheel bolts. In a similar way, take a piece of angle steel, drill two holes in it that fit two of the bolt holes on one side of the carrier flange, to hold it. Quote
Dawa Posted August 2, 2012 Report Posted August 2, 2012 thanks i appreciate it! actually when i was laying in bed last night i figured out i would pretty much do the same thing... fab something up with some metal using a drill and no welding. thanks again. Quote
