HRH Posted May 25, 2012 Report Share Posted May 25, 2012 I'm trying to figure how the bead breaker attaches on the right side of the machine. I see the bar with a bolt that should engage the post with the cut outs but it doesn't hold itself there. Almost seems like I'm missing some portion of it. Going to stop by Schwabs to see if I they might have an old one I can look at. It's been a while since I've used a center post. Quote Link to comment
Guest Rick-rat Posted May 25, 2012 Report Share Posted May 25, 2012 I believe that the bead breaker is not supposed to be permanentley attached, it is meant to be loose to swing out of the way once the bead is broken, what holds it in place is the wheel and tire after you hook the clamp part over the rim, then it should catch when the pedal is depressed, the bottom bead breraker will move first and then the top bead breaker should engage. Can't remember what I did yesterday, but can remember stuff from over 40 years ago Quote Link to comment
HRH Posted May 26, 2012 Author Report Share Posted May 26, 2012 I believe you're correct. The next version, the 4040 had a swivel head but the stem mounted permanently below. This just sits there on the rim and you lift it back out of the way. Figured out how to use it after some trial and error. Works fine, just a bit slower for operation. Sufficient for my purposes though. Changed two tires on the Sentra today, almost have it ready for sale. Passed emissions need to fix a few little things still. Quote Link to comment
Guest Rick-rat Posted May 26, 2012 Report Share Posted May 26, 2012 I'm glad you figured it out Quote Link to comment
Nick brill Posted November 17, 2022 Report Share Posted November 17, 2022 Hi guys I bought a coats 30-30-a tire changer everything on it works but when you go to break the bead it is to weak to break it my air compressor is 150 psi I don’t hear any leaks just wondering what I could do Quote Link to comment
datzenmike Posted November 17, 2022 Report Share Posted November 17, 2022 Did you remove the valve from the stem???? I've removed literally hundreds of tires at a local auto wreckers. The tire changer couldn't compress the tire off the bead if there was air in the tire. It would strain like hell but couldn't budge it. Let the air out and it was fine. Quote Link to comment
bilzbobaggins Posted November 17, 2022 Report Share Posted November 17, 2022 is the line pressure out of the compressor set to maximum? I can break beads with my twin tank dewalt, and thats a small sucker. Not a coats machine. At least I dont think Quote Link to comment
datzenmike Posted November 20, 2022 Report Share Posted November 20, 2022 Was it the valve???? Quote Link to comment
]2eDeYe Posted November 20, 2022 Report Share Posted November 20, 2022 On 11/16/2022 at 4:10 PM, Nick brill said: Hi guys I bought a coats 30-30-a tire changer everything on it works but when you go to break the bead it is to weak to break it my air compressor is 150 psi I don’t hear any leaks just wondering what I could do Are you breaking the back bead first? Quote Link to comment
