Stoffregen Motorsports Posted May 3, 2012 Report Share Posted May 3, 2012 http://sacramento.cr...2979361253.html I do have his email if the link no longer works. He was asking $600 for it. Quote Link to comment
Farmer Joe Posted May 3, 2012 Report Share Posted May 3, 2012 its like really ratty rusty ruth... rubys older aunt... :lol: Quote Link to comment
erichwaslike Posted May 3, 2012 Report Share Posted May 3, 2012 just fyi its a 67, no 411s in 68... and i know its 67 cause its a 1600 bw auto car. Quote Link to comment
Stoffregen Motorsports Posted May 3, 2012 Author Report Share Posted May 3, 2012 just fyi its a 67, no 411s in 68... and i know its 67 cause its a 1600 bw auto car. I just posted it as it is in the ad. How hard are these to find parts for? I mean stuff like window rubber and door hinges and chrome? Quote Link to comment
bonvo Posted May 3, 2012 Report Share Posted May 3, 2012 typical rule of thumb is the older the datsun the harder it is to find parts for it Quote Link to comment
MikeRL411 Posted May 4, 2012 Report Share Posted May 4, 2012 Body parts are a real problem. Some 520 or 521 front fenders can be made to fit with immagination and time. Looks like you are clear on that part. Hoses can and must be modified from available Gates Rubber and Goodyear items. I have part numbers that can be used. The hardest to find parts are the original air cleaner housing and especially the filters. They look like the roadster ones but are an inch shorter because of the lack of clearance to the brake master cylinder and firewall. Water pumps were always a hard to find item. You have to modify a roadster unit by transplanting the "spinner" from an original RL411 pump with the one from the roadster pump. This will leave an inch of waterpump shaft meanacing your radiator so have good motor mounts or get the extra inch of shaft cut off. There is a "well" behind the rear wheel and the trunk floor that is covered with a cardboard filler piece. The well is prone to rusting through to the wheel well. If in relatively good shape, flush with Naval Jelly, apply Rustolium generously, let dry and fill the void with low expanding urethane foam. As it rises to the top of the well, wet your hands and compress and densify the top skin to as close to flat as you can. The old cardboard filler plates covered with Saran wrap may help to make the cured surface flat. Throw the cardboard filler plates away or sell them to someone who is desperite to preserve originality. When cured, prime and paint to preserve the foam. It works! Quote Link to comment
erichwaslike Posted May 4, 2012 Report Share Posted May 4, 2012 I just posted it as it is in the ad. How hard are these to find parts for? I mean stuff like window rubber and door hinges and chrome? its pretty dfficult if you dont know where to look or who to talk to. or you can just look in my shop. ive got extra roos and chrome and many 411 sss specific parts that i grab when i see them to keep them from getting thrown out or somethin. yes i horde but in a good way cause ive helped a good few 411 owners get parts they otherwise woodnt be able to locate. Quote Link to comment
Wisepuppet Posted May 6, 2012 Report Share Posted May 6, 2012 Hey I'm after so 411 front indicators and maybe some tail lights too....more just for the rubber gasket in the tail light. Also the correct profile for the rubber door seals. Are you able to help with any of this? I may have the only 411 on the road in New Zealand so am struggling to find the things I need. James Quote Link to comment
MikeRL411 Posted May 6, 2012 Report Share Posted May 6, 2012 Hey I'm after so 411 front indicators and maybe some tail lights too....more just for the rubber gasket in the tail light. Also the correct profile for the rubber door seals. Are you able to help with any of this? I may have the only 411 on the road in New Zealand so am struggling to find the things I need. James For discussion on door seals see " 3 "Universal" Weatherstrip Solutions " entries below. Quote Link to comment
erichwaslike Posted May 7, 2012 Report Share Posted May 7, 2012 Hey I'm after so 411 front indicators and maybe some tail lights too....more just for the rubber gasket in the tail light. Also the correct profile for the rubber door seals. Are you able to help with any of this? I may have the only 411 on the road in New Zealand so am struggling to find the things I need. James i have a few tail light gaskets.... no front indicators. espesically aus spec ones... no door seals here. Quote Link to comment
MikeRL411 Posted May 8, 2012 Report Share Posted May 8, 2012 Hey I'm after so 411 front indicators and maybe some tail lights too....more just for the rubber gasket in the tail light. Also the correct profile for the rubber door seals. Are you able to help with any of this? I may have the only 411 on the road in New Zealand so am struggling to find the things I need. James Below is a lead on a KIA door seal that can be made to fit a 521 door. Most likely these seals can also be made to fit a 411 since cutting is required. Don't know if Oz has this KIA model but happy hunting!. http://community.ratsun.net/topic/42623-521-door-seals/ Quote Link to comment
MikeRL411 Posted May 8, 2012 Report Share Posted May 8, 2012 Hey I'm after so 411 front indicators and maybe some tail lights too....more just for the rubber gasket in the tail light. Also the correct profile for the rubber door seals. Are you able to help with any of this? I may have the only 411 on the road in New Zealand so am struggling to find the things I need. James Probably not too good for you in New Zealand but this offer in Parts for Sale http://community.ratsun.net/topic/43231-67-520-front-half-parts/ has 1967 pickup forward clip parts for sale. The fenders, hood and front bumper can be coerced into suitable 410 or 411 replacement parts! Quote Link to comment
