datsun 521 ute Posted April 21, 2012 Report Share Posted April 21, 2012 Okay so I am putting together the new upper link shafts and was wondering which way the seals go? A: B: Also what is the O-ring for as there wasn't one when I took the old ones apart? Quote Link to comment
datzenmike Posted April 21, 2012 Report Share Posted April 21, 2012 My diagram shows from the out side, moving inwards... grease nipple, bushing assy, outer dust seal, dust seal clamp, inner dust seal, and the upper link all this goes on. Quote Link to comment
datsun 521 ute Posted April 22, 2012 Author Report Share Posted April 22, 2012 My diagram shows from the out side, moving inwards... grease nipple, bushing assy, outer dust seal, dust seal clamp, inner dust seal, and the upper link all this goes on. Does it show which way up the inner dust seal goes, is it the same as the first or second picture? Thanks for the help. Quote Link to comment
datzenmike Posted April 22, 2012 Report Share Posted April 22, 2012 Can't tell. Bet Mklotz70 would know... Quote Link to comment
wayno Posted April 22, 2012 Report Share Posted April 22, 2012 If I were to guess, I would say the first photo, same as the way the harmonic balancer seal goes in. I just pulled my new upper bushing setup apart, and there was no seal in there, and I bought them new. Quote Link to comment
mklotz70 Posted April 23, 2012 Report Share Posted April 23, 2012 I ran out of time to take pics today, but Wayno and I looked at an arm I had. The seals were in good shape, but I have no clue if they were untouched from the factory or if they've been replaced in the past. The seals were in like the second picture. I would think that they should be in like the first pic. I'll try to pop the seals tomorrow and take some pics. Here's the exploded view from the parts manual.....like Mike said...you can't tell which way it's supposed to go..... 39....seal - dust, inner 40....clamp - dust seal 41....seal - dust, outer No indication of any o-ring, but I would suspect that the o-ring is intended to be the clamp. Normally, the clamp is a metal spring, but I can see an oring working. Maybe???? With the way the outer dust shield fits, I don't really think it needs the clamp. The chassis manual doesn't show any detailed pics either. Quote Link to comment
datsun 521 ute Posted April 23, 2012 Author Report Share Posted April 23, 2012 Thanks heaps guys for your help. I did find a seal still in one of the old bushes and it was in the way like picture 2. Looking at the seals I would have thought for them to go like picture 1 as this would help retain the grease within the seals. Also I know this car has had alot of maintenence and can't be certain if this is from factory or someone has changed it. There were no clamps on the outer seals either when I took them apart, either fallen off or not put back on when or if they were changed. Quote Link to comment
Tucson620 Posted April 23, 2012 Report Share Posted April 23, 2012 I need to replace these bushes on my truck. Did you spring for the Ni$$an dealer parts or find a different source? My upper links can wobble almost 1/4" due to these bushes - hopefully the last of my front suspension issues (cause I replaced everything else!). Quote Link to comment
datsun 521 ute Posted April 23, 2012 Author Report Share Posted April 23, 2012 I need to replace these bushes on my truck. Did you spring for the Ni$$an dealer parts or find a different source? My upper links can wobble almost 1/4" due to these bushes - hopefully the last of my front suspension issues (cause I replaced everything else!). I bought new complete kits off ebay a little while from a guy in Aisa. Quote Link to comment
