DISLEXICDIME Posted March 30, 2012 Report Share Posted March 30, 2012 Any one know what gauge sheet metal the floor pan is in a dime? Quote Link to comment
INDY510 Posted March 31, 2012 Report Share Posted March 31, 2012 . In the thinnest places it looks slightly thinner than 20 guage ..... ... maybe 22ag???? ...... but you could probaly cut a 510 in half with a MIG welder,,,, because the metal is so fucking thin I wouldn't use anything thinner than 18-20ag .. ... even if it's a small patch . ,,,, because it's really easy to burn holes in the floor Quote Link to comment
I'm BLUE Posted March 31, 2012 Report Share Posted March 31, 2012 INDY has it spot on 100% ... i used 18-gauge on my 240z floor board and frame in-lay ... its def thicker than stock but if you dont have mig/gas it can be difficult ... Take the area you think you can patch/weld in successfully .... and times it by 3 ... for worst case scenario ... i get picky though lol 18-gauge steel 4ftx4ft sheet = shouldnt cost more than $38.00 I dont know the prices for 20 or 22 gauge Goid luck :) Quote Link to comment
DISLEXICDIME Posted March 31, 2012 Author Report Share Posted March 31, 2012 Thanks guys Quote Link to comment
DanielC Posted March 31, 2012 Report Share Posted March 31, 2012 Here are approximate thicknesses, and the gauge number. You can measure the metal witha micrometer, some calipers, or even compare it a feeler gauge, by feeling a difference in thickness. Be aware that where the metal is stamped into a compound curve, it most likely stretched to form the curve, and will be thinner. .022 = 24 ga .025 = 23 ga .028 = 22 ga .032 = 21 ga Approx 1/32" .035 = 20 ga .042 = 19 ga .049 = 18 ga .054 = 17 ga .065 = 16 ga Approx 1/16 Quote Link to comment
DISLEXICDIME Posted April 10, 2012 Author Report Share Posted April 10, 2012 any one tried welding a piece of angle iron to the inside of the rocker so you have something that is not pencil thin then weld the floor to the angle ? Quote Link to comment
Uber Deaf One Posted April 10, 2012 Report Share Posted April 10, 2012 any one tried welding a piece of angle iron to the inside of the rocker so you have something that is not pencil thin then weld the floor to the angle ? I don't see why you wouldn't be able to do that... if it makes the job easier, go for it. Quote Link to comment
merlin Posted April 11, 2012 Report Share Posted April 11, 2012 yup 20 guage is nice to bend, but 18 is much better to weld.... get a weld punch and do spot welds or lap welds on your seams... less likely to blow through the metal. Use weld through primer too for metal prodtetion so you don't have to do it again in 3 years. Quote Link to comment
