Project Pistachio
Zeusimo
  • Replies 132
  • 1 month later...
  • 3 weeks later...
So About A Week Ago I Got In My Car To Go To Work
I Turn The IGN And Nothing...
All The Lights Would Work Until I Try To Start
Not Even A Click
When I Got Home I Charged My Battery (Which Wasn't Dead...But I Thought It Was)
Nothing....
Anyways My Wiring Was Done
Just a Small bit of info... which you may already know, but just in case....
It is possible to make adjustable front end geometry by lopping the ends off the control arms and welding in threaded heim joints. You can trim back the shoulder of the T/C rods and use washers to set caster as desired. Getting rid of the control arm rubber gives great feel, but a little more vibration at the steering wheel.  (the heim joints also let you adjust front track width if you want)
I only mention this because you are clearly taking the time to make a lot of solid improvements, and you are already halfway down the path I went  when setting up my 510 for Auto-x...(280zx struts, 240 inserts, and coilovers etc)  not gonna take my 710 wagon that far, but I have to figure out something for getting it lowered.
Your page gave me some clues about wagon height, etc after swapping various bits... so I figured I would try to contribute something of value in return.
Any plans to use Aluminum Z drums out back as well?
All My Headlights Were Twisted Together Using Speaker Wire
I Swear Fixing PO's Wiring Got Me So Madd
I Found A Rear End With Only 80,000 Miles On It
Going To Clean It Up And Swap It Over Next Weekend
I Know What You Are Talking About With The Joints
But This Is Just My Daily Driver
I Already Bought Polyurethane LCA Bushings
Changing Them Sucks Tho
I Have To Take Them To A Machine Shop
Which Means I'm Out A Car For 2 Days
I'm Also Considering Some Hushmat
It's Sooo Loud Inside My Car
I Don't See How That Would Work Unless I Got Longer Brake Lines
Don't your factory hardlines come out about 1" back from being in line with the strut? If so, it's just a matter of running them a different way. Nothing to change. All you have to do is rebleed the brakes. If for some reason your hoses are really short, I can see it being a problem, though...
If you don't want to, that's cool. Just trying to offer a $0 option to your issue.  :thumbup:
