Project Pistachio
Zeusimo
  • Replies 132
The Rod For The Pedal Is 1/2 Shorter Compared To 610
There Was Only A Few Threads Holding For Full Brake Pedal Travel
It Would Work But I Wasn't Sure If It Would Break If I Brake Suddenly
So I Whipped Out The TIG And Welded A Nut To The End
Retapped The Threads And It Works Perfectly
Got My NCRCAs
Soo Much Room For The Caliper Now
These Made My Steering Really Sharp
I Also Feel Like The Sway Bar Has Been Upgraded
No More Bumpsteer Either
It's So Nice Not Having To Hold Your Steering Wheel So Tight
Well Worth $150
It Probably Was Mine
The Whole Pass Side Of The Car
Is Pushed In ALOT From Previous T-Bone
To Me That Makes The Car Worthless
But Instead Of It Going To The JY
I'll Just Make A Functional Commuter Car
Nothing Fancy
Comfy Suspension - Done
Decent Brakes - Done
Quiet - Looking Into Hushmat And Some Carpet
The Motor Needs Some Work
Maybe I'll Just Get A KA And Call It Good
Your wagon is looking great.
Does not look like there is major damage at all. Agree it is not flawless but certainly not worthless.
No worries, many 510's i've seen are not flawless at all. Many have been raced or got into accidents and yet end up in good shape.
If push comes to shove there are always good wagons around, with great bodies and not running for a token.
But your wagon does not seem to need such surgery.
Keep the good work rolling.
  • 2 months later...
I Adjusted The Carb As Best As I Could Lots Of Times
The AFR Was Constant 18 At Best
When I Lower The RPM Under 800 The AFR Is At 30
Weird Thing Was When I Spray Starting Fluid At The Carb
It Dies As If It Was Really Running Rich
Timing Was At 10*
I Know It Is Not A Carb Problem Because
I Put The Carb On My Truck And There Wasn't A Problem
1 - Leaking 10% With 135 Compression
2 - Leaking 25% With 120 Compression
3 - Leaking 15% With 130 Compression
4 - Leaking 25% With 120 Compression
I Decided To Rebuild The Motor
Haha I Gave My Little Sister My Old Gameboy Color
So She Can Play Some REAL Games Like Pokemon Yellow!
At This Point I Started Lining Up The Timing Chain Marks
Weird Thing Is At TDC My Timing Mark Is At 10 Degrees
I Removed The Timing Cover And Chain And Checked 3 Times
Maybe I Have The Wrong Mark Or Pulley
Maybe It Was Like This Before I Pulled The Motor
That Would Explain It Never Pinging At 25 Degrees At Idle
I Turned It Down To 10 To Be Safe Making It Really 0
That Would Explain The Previous Lousy Performance
A87 Peanut Head
I Measured It And It Has Been Cut .033
I Installed Two Set Of Shims And Align Honed
I Forgot To Measure The CCs
Runners Were Smoothed And Polished
Also Installed Aftermarket Springs And Retainers
That I Picked Up At Datsloco A While Back
Also Installed A Few Time-Serts
Installed Motor And Mocked Up A Scirocco Radiator From My Truck
It Almost Fits But The Filler Cap Hits The Batt
I Would Have To Cut The Filler Neck
Then Weld It Back On Straight Up And Down
But That's A Project For Another Day
