m_adamson_no_1 Posted March 14, 2012 Report Share Posted March 14, 2012 i recently obtained a 73 datsun 620 pick up in the process of puttin a small block 350 and 700r4 trans an comments or advice would b greatly appreciated the truck the motor the trans front clip removed the motor set in place again inner fender well clearance driver passenger front clip set in place Quote Link to comment
MicroMachinery Posted March 14, 2012 Report Share Posted March 14, 2012 Welcome. Now ditch the Fram. Quote Link to comment
Jayden71 Posted March 14, 2012 Report Share Posted March 14, 2012 Welcome. Now ditch the Fram. X2!! :cool: Quote Link to comment
datzenmike Posted March 14, 2012 Report Share Posted March 14, 2012 Hmmmm... remove heater and start cutting the firewall and tunnel out. Get a disc brake kit from on here. 'Cuz you WILL need to stop that thing. Did you keep the torsion bars, I can't see them. If they are gone you don't need that bolt in brace across under the pan. The diff is 4.375 and many 2wd 720s have 3.889 or 3.70 even down to 3.545 and lower that you can just. bolt the pumpkin in. Someone asking about putting a V8 in a 620 is kind of cliche around here. Doing it is another story. Good luck with this. Quote Link to comment
m_adamson_no_1 Posted March 14, 2012 Author Report Share Posted March 14, 2012 Welcome. Now ditch the Fram. ya no oil or anything in it just keepin it there for the mess lol Quote Link to comment
m_adamson_no_1 Posted March 14, 2012 Author Report Share Posted March 14, 2012 Hmmmm... remove heater and start cutting the firewall and tunnel out. Get a disc brake kit from on here. 'Cuz you WILL need to stop that thing. Did you keep the torsion bars, I can't see them. If they are gone you don't need that bolt in brace across under the pan. The diff is 4.375 and many 2wd 720s have 3.889 or 3.70 even down to 3.545 and lower that you can just. bolt the pumpkin in. Someone asking about putting a V8 in a 620 is kind of cliche around here. Doing it is another story. Good luck with this. removed all suspension out of front along w front brace installed aftermarket motor mounts/crossmember going to run a solid axle out of a 30s style chevy pick up and narrow it ive got 95%of the stuff to install everything so just a matter of doing it lol 1 Quote Link to comment
Eagle_Adam Posted March 14, 2012 Report Share Posted March 14, 2012 your not the 1st person ive seen come in with the idea of stuffing a V8 into a 620, however you are the first to have all the parts and supply pics to support your cause! +1 im subscribing just to see where it goes :D Quote Link to comment
]2eDeYe Posted March 14, 2012 Report Share Posted March 14, 2012 Welcome, nice start :cool: Quote Link to comment
K_trip Posted March 14, 2012 Report Share Posted March 14, 2012 Welcome Your post reminded me of a Datsun that got some press after the 2009 SEMA show ... ... small block powered 620 for the strip. Sounds like fun to me! Here is a link to some more of this truck http://www.hubgarage.com/mygarage/jake1963/vehicles/45171 Good luck with it - and keep us posted 1 Quote Link to comment
pharouh Posted March 17, 2012 Report Share Posted March 17, 2012 A 30's style straight front axle in a 620? I want to see that. Are you going to use coliovers or go with a leaf spring? Quote Link to comment
lil89ram50 Posted March 17, 2012 Report Share Posted March 17, 2012 foir some reason, i just do not see this getting finished anymore. not after seeing the box al cut up in one of thses pics... and talk of a straight axle Quote Link to comment
m_adamson_no_1 Posted March 17, 2012 Author Report Share Posted March 17, 2012 Sure is alot of negativity round here lol and for ur information its called a c-notch kinda have to cut out the bed and to not build something cuz the bed isnt bolted down is kinda a dumb reason if u read my descr it says FRAME OFF thanks for the motivation tho :-) and to pharough just running the leaf springs for now and itll b mono leafed in the rear w coils for now till i possibly link it Quote Link to comment
m_adamson_no_1 Posted March 25, 2012 Author Report Share Posted March 25, 2012 here is for all u nay sayers lol progressing still alot of work but trying Quote Link to comment
sick620 Posted March 29, 2012 Report Share Posted March 29, 2012 big project ahead of you... keep it comin:) Quote Link to comment
DailyRacer Posted July 13, 2012 Report Share Posted July 13, 2012 71 521 365 Mopar 5 speed 4 wheel disk isr rearend i have no idea how much money i quit saving receipts a long time ago but it was about 2 million hours 1 Quote Link to comment
