The datsun kid Posted March 11, 2012 Report Share Posted March 11, 2012 Hey guys I bought a l20b with 4speed from a 77 710 and am going to put it in my 71 521 ( l16 4speed) the output shaft on my new tranny won't fit the drive shaft end in my truck so is there any thing i can do and my old tranny is shot plz help guys we're in the middle of the swap Quote Link to comment
metalmonkey47 Posted March 11, 2012 Report Share Posted March 11, 2012 Can't say I really have any advice to give here, but someone will come along shortly who does. Good luck man! I know how it is to hit a bug half way through a swap. Quote Link to comment
Pumpkn210 Posted March 11, 2012 Report Share Posted March 11, 2012 Make sure the trannys are the same length and have the correct yoke put on your driveshaft... Quote Link to comment
datzenmike Posted March 11, 2012 Report Share Posted March 11, 2012 Unbolt the flanged spline from the back of the 521 4 speed and pull it out. Put a 40mm engine frost plug (with sealer or it will drip oil) over the hole where the nut was and that should do it. It will now fit the 710 4 speed tailshaft and the rest of the 521 driveshaft should bolt back to it. How easy is that??? . 2 Quote Link to comment
The datsun kid Posted March 11, 2012 Author Report Share Posted March 11, 2012 Ohh mmmmmmyyyyyyyyy Gggggggoooooooooddddddd mmmmmmiiikkeee your the man!!!!!! Quote Link to comment
HRH Posted March 11, 2012 Report Share Posted March 11, 2012 Sweet, Mike to the rescue!! Quote Link to comment
datzenmike Posted March 11, 2012 Report Share Posted March 11, 2012 Meh... It was nothing really, just a slow afternoon. Quote Link to comment
HRH Posted March 11, 2012 Report Share Posted March 11, 2012 Superman always has to be modest. :rolleyes: Quote Link to comment
bonvo Posted March 11, 2012 Report Share Posted March 11, 2012 mike is the tranny god Quote Link to comment
The datsun kid Posted March 11, 2012 Author Report Share Posted March 11, 2012 I feel like they're needs to be a platinum sculpted statue of mike and the name plate says "the messiah" Quote Link to comment
bonvo Posted March 11, 2012 Report Share Posted March 11, 2012 I feel like they're needs to be a platinum sculpted statue of mike and the name plate says "the messiah" idea for canby trophy right there Quote Link to comment
The datsun kid Posted March 11, 2012 Author Report Share Posted March 11, 2012 See!! He inedvertinly creates solutions to problems! Quote Link to comment
Pumpkn210 Posted March 11, 2012 Report Share Posted March 11, 2012 +1 Mike! I thought it was different splines. Learn something new every day! That's a great trick ;-) Quote Link to comment
Hardwyre Posted March 11, 2012 Report Share Posted March 11, 2012 There won't be any issue with running the tranny without that retaining bolt? Quote Link to comment
datzenmike Posted March 11, 2012 Report Share Posted March 11, 2012 None. The 521 has a second driveshaft behind the carrier bearing with a slip joint. Because of this they (for whatever reason) bolted the front spline into the transmission output spline. I think the 240z had the bolt in spline also or maybe the Roadster because the diff was bolted to the frame and there was no driveshaft movement to worry about. All other trucks use the sliding spline. bonvo you have to come to Canby! Quote Link to comment
SpudWhitman Posted March 11, 2012 Report Share Posted March 11, 2012 bonvo you have to come to Canby! For many are called, but few are chosen. Quote Link to comment
bonvo Posted March 11, 2012 Report Share Posted March 11, 2012 bonvo you have to come to Canby! dont worry mike im doing everything in my power to make it out there selling stuff saving part of my tax return im even making sure that when i fill out applications i tell them i wont be able to work for a week just so i can make canby Quote Link to comment
