  • Replies 16
Unbolt the flanged spline from the back of the 521 4 speed and pull it out.
Put a 40mm engine frost plug (with sealer or it will drip oil) over the hole where the nut was and that should do it. It will now fit the 710 4 speed tailshaft and the rest of the 521 driveshaft should bolt back to it. How easy is that???
None. The 521 has a second driveshaft behind the carrier bearing with a slip joint. Because of this they (for whatever reason) bolted the front spline into the transmission output spline. I think the 240z had the bolt in spline also or maybe the Roadster because the diff was bolted to the frame and there was no driveshaft movement to worry about. All other trucks use the sliding spline.
bonvo you have to come to Canby!
dont worry mike im doing everything in my power to make it out there selling stuff saving part of my tax return im even making sure that when i fill out applications i tell them i wont be able to work for a week just so i can make canby
