rome11six Posted March 10, 2012 Report Share Posted March 10, 2012 ok so i went to flip my center link for clearance on my ka swap but found out the holes are tapered. so with that said how do you flip the link.... do i drill the hole out and flip it, do i taper it bigger and get a bigger end, how do i do it? Quote Link to comment
flatcat19 Posted March 10, 2012 Report Share Posted March 10, 2012 All out of spoons. Go buy a back issue of Project Car. Or use the button up in the right upper corner. Been covered. Quote Link to comment
DAT510 Posted March 10, 2012 Report Share Posted March 10, 2012 All out of spoons. Go buy a back issue of Project Car. Or use the button up in the right upper corner. Been covered. The red button on the upper right? that closes the browser, Why would you close the browser? :lol: Quote Link to comment
flatcat19 Posted March 10, 2012 Report Share Posted March 10, 2012 The red button on the upper right? that closes the browser, Why would you close the browser? :lol Maybe if one was to close browser, the would see the Google box right below it? Quote Link to comment
DAT510 Posted March 10, 2012 Report Share Posted March 10, 2012 Maybe if one was to close browser, the would see the Google box right below it? Quote Link to comment
crackerjack69 Posted March 10, 2012 Report Share Posted March 10, 2012 Weld the hole shut. Ream from the other side. If you "found out the hole was tapered", you should consider paying someone to do this. Quote Link to comment
flatcat19 Posted March 10, 2012 Report Share Posted March 10, 2012 If you "found out the hole was tapered", you should consider paying someone to do this. :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: Quote Link to comment
wayno Posted March 10, 2012 Report Share Posted March 10, 2012 I had one tapered both ways, I was able to put the tierod in either way, it takes a special tool. Quote Link to comment
]2eDeYe Posted March 10, 2012 Report Share Posted March 10, 2012 This is the cheapest. http://www.goferitoffroad.com/products.htm You can also weld it up and re-drill it with the correct tapered bit. Quote Link to comment
datzenmike Posted March 10, 2012 Report Share Posted March 10, 2012 ... it takes a special tool. Quote Link to comment
rome11six Posted March 14, 2012 Author Report Share Posted March 14, 2012 Thanks guys........ i realized it was tapered i just worded it wrong. i meant to ask how you guys flipped it so i could get some other ideas (thanks j2eDeYe for the info) . and i do have the project car mag issue No. 19 witch shows how to make a custom link using spherical rod ends, and alot of other useful stuff for the swap! Quote Link to comment
]2eDeYe Posted March 14, 2012 Report Share Posted March 14, 2012 Eric updated his thread and those inserts are not the correct taper. You can weld up the holes and get the correct taper bit to re-drill them. Quote Link to comment
