skyblue Posted April 14, 2014 Report Share Posted April 14, 2014 When you go moar low, you go moar low!! 1 Quote Link to comment
Farmer Joe Posted April 14, 2014 Report Share Posted April 14, 2014 DAMN! thats INDY510 low in the front... i approve this message! 2 Quote Link to comment
TENDRIL Posted April 14, 2014 Report Share Posted April 14, 2014 Nope......how old are you?? If you're under 29-30.....you might have a harder time....... ahhh im 24..... soome sort of 80's nostalgia?? 1 Quote Link to comment
Busta Nut Posted April 14, 2014 Author Report Share Posted April 14, 2014 ^^........yes ......even early 90s.... Quote Link to comment
mttam510 Posted April 14, 2014 Report Share Posted April 14, 2014 I obviously cannot drive it this low......can't turn the wheel more than a 1/4 turn before tire hits the fender........ I raised it up and went for a short drive with Skyblue and FtO......by this time it's about 1:30a.m. Forgot to get oics with all the excitment..... Went home and parked.........came out to this the next morning...... Fuck....... ooffa! 1 Quote Link to comment
mttam510 Posted April 14, 2014 Report Share Posted April 14, 2014 I just snapped some pics of my current front strut 280Zx casings...you are a little lower than i am on the lower perch that should be welded to the strut casing :). I am about 9.75" from where the tube inserts into the spindle to the surface the the 102mm GC threaded collar sits on. Still have room to go down although, it would be too much low... 1 Quote Link to comment
Busta Nut Posted April 14, 2014 Author Report Share Posted April 14, 2014 Nice.....yes this is too low......don't know why anyone would need a shorter strut than this........... What happened was the split collar slipped..........but the strange thing is that it did not slip while I was driving it......... ..........not till it sat overnight.......being clamped over the paint was a bad idea......and I thought about it briefly but didn't think it would be this big an issue.......since this wasn't permanent.... 1 Quote Link to comment
TENDRIL Posted April 14, 2014 Report Share Posted April 14, 2014 metal contracted? 1 Quote Link to comment
Busta Nut Posted April 14, 2014 Author Report Share Posted April 14, 2014 Maybe.......didn't think it got that cold.... I have to beg my landlord now for 20 min of car time........we can't open our hoods @ our building without being bitched at...... :poop: Quote Link to comment
Farmer Joe Posted April 14, 2014 Report Share Posted April 14, 2014 did both sides slip or just one? will it still roll? youll need to put 2 beefy tack welds on either side of the strut tube if youre gonna keep using the clamps. 2 Quote Link to comment
Busta Nut Posted April 15, 2014 Author Report Share Posted April 15, 2014 Both sides.....weird shit.....barely rolls.....scrapes the ground though........ Like I said earlier......this was temp to find the height I want to leave them at.......I want perches welded in....... Landlord granted time :sweat: 1 Quote Link to comment
Ranman72 Posted April 15, 2014 Report Share Posted April 15, 2014 Nice.....yes this is too low......don't know why anyone would need a shorter strut than this........... What happened was the split collar slipped..........but the strange thing is that it did not slip while I was driving it......... ..........not till it sat overnight.......being clamped over the paint was a bad idea......and I thought about it briefly but didn't think it would be this big an issue.......since this wasn't permanent.... that is to low couldnt help myself you didnt clamp it tight enough because you didnt want to scratch the paint Quote Link to comment
Ranman72 Posted April 15, 2014 Report Share Posted April 15, 2014 a hair curler Quote Link to comment
Busta Nut Posted April 15, 2014 Author Report Share Posted April 15, 2014 that is to low couldnt help myself you didnt clamp it tight enough because you didnt want to scratch the paint I think when you scrape the ground with the sub frame it is classified as too low...... When you can't move you're car because the frame catches pebbles......you might be too low....... I tightened the shit out of them...and locktite...... ......and no it's not from a hair curler 1 Quote Link to comment
Janksun Posted April 15, 2014 Report Share Posted April 15, 2014 Fuckin slammed!! I say leave it lmao 1 Quote Link to comment
Laecaon Posted April 15, 2014 Report Share Posted April 15, 2014 what material are your collars? Aluminum or stainless? Steel usually comes in black oxide but also have the highest axial loading forces. Quote Link to comment
Busta Nut Posted April 15, 2014 Author Report Share Posted April 15, 2014 what material are your collars? Aluminum or stainless? Steel usually comes in black oxide but also have the highest axial loading forces. Aluminum.......paint was the culprit....... Quote Link to comment
Laecaon Posted April 15, 2014 Report Share Posted April 15, 2014 I doubt it. Mine were over paint. Aluminum have a far weaker axial load than either steel or stainless collars. But I guess it could be paint... Quote Link to comment
Farmer Joe Posted April 15, 2014 Report Share Posted April 15, 2014 ive gotta say it looks fuckin boss sittin low like that tho... glad you got it figured... i was thinkin about what jake said about the collars being aluminum.. you think they stretched out and lost grip? the paint seems the likely culprit, but i was just wonderin... 1 Quote Link to comment
tr8er Posted April 15, 2014 Report Share Posted April 15, 2014 Steel would press the paint till it wasn't an issue. I was about to eat my words till I read that. Aluminum is less than a quarter of the rated load. No good. Hardened steel only. Also won't lead to problems with dissimilar metals. 1 Quote Link to comment
Busta Nut Posted April 15, 2014 Author Report Share Posted April 15, 2014 ive gotta say it looks fuckin boss sittin low like that tho... glad you got it figured... i was thinkin about what jake said about the collars being aluminum.. you think they stretched out and lost grip? the paint seems the likely culprit, but i was just wonderin... It does look fuckin' BOSS.......wish it could be driven this low....... Bolts were still pretty tight around the collars.....my guess is the paint wasn't completely cured......re positioned and tightened the shit out of them again...... Also installed a bigger bump stop so it doesn't fall to the ground and get me stuck somewhere....... Took her for another drive this morning with the bigger bump stop and height set to 21.5" to the fender lip.......tire is just about level with the fender.....no tuck.... Koni shocks set to sport......that's the middle setting on these....#3 of 5......175lb springs..... Must say the ride is pretty cush and no rubbing at all......I'll take her out for a harder drive at lunch to see if the fender rubs on hard turns...... OICS...... 2 Quote Link to comment
skyblue Posted April 15, 2014 Report Share Posted April 15, 2014 Pics of new ride height? Quote Link to comment
Busta Nut Posted April 15, 2014 Author Report Share Posted April 15, 2014 They're comin......got busy for a sec.... Hammered the pinch welds cause they were hitting the tires.... Quote Link to comment
Busta Nut Posted April 15, 2014 Author Report Share Posted April 15, 2014 New height for now......more driving needs to be done to see where it bottoms and how much rubbing goes on...... I'd like to go lower.....but I'll probably need stiffer springs..... 2 Quote Link to comment
