burrito213 Posted February 27, 2012 Report Share Posted February 27, 2012 so i just bought a decent brake tubing double flaring kit and was wondering if there was certain size for the 320 to use for brake line? i am assuming 3/16 but i am not too sure. spent the last half hour looking for threads saying so and carparts manual just shows the brake lines, not the dimentions unless i am wrong. any help? thank you. Quote Link to comment
twizted320 Posted February 27, 2012 Report Share Posted February 27, 2012 3/16 would be my guess also, but id wait to hear more opinions! Quote Link to comment
I'm BLUE Posted February 27, 2012 Report Share Posted February 27, 2012 Are you running stock brakes? That sounds close ... Planning for upgrades? (Nows a good time ;-) Org restoration? What are your exact concerns? :) Summit racing, speedway, and Jegs all sell brake line tubing kits, with ends, sleeves and good stuff .... but the ends you need may not match up .... more likely not ... For thicker BIGGER brake line, ,,, a cheaply bended may or may not do it ... While bending brake lines ... consider bending and running new fuel lines if metal :) I will end up in your position as i will be running yota 4x4 quad piston calipers up front and ford lsd 8.8 rear rotor/rear disc brake calipers in the rear of my 71 240z .... If your super unsure .... go to a parts store .... look at different pre-made brake line lengths and diameters ... than ask questions to clerk. Better yet pm mklotz70 he would have a good idea :cool: Quote Link to comment
burrito213 Posted February 27, 2012 Author Report Share Posted February 27, 2012 haha...yup i am doing a disk/drum conversion using mklotz brackets that will help with the braking. this is what i have so far and plan to get: double reservoir m/c ...forgot which one for the moment but will look iy up when i get home 720 calipers... i think this is what charlie69 said to buy and what Wayno said i had on his winshie;d drop off stock drums in the back lisle #31310 double brake line flaring kit 2 different type brake line tube benders from HarborFrieght plan to get (if the correct one) eastwoods 25' brake line tubing 3/16 diameter with asst. fittings... steel tubing Quote Link to comment
DanielC Posted February 27, 2012 Report Share Posted February 27, 2012 521 trucks use 3/16 brake line, and flare nuts with 3/8-24 threads. I would think the 320 trucks are the same. Wayno, or MikeK will probably know for sure. Quote Link to comment
RAlly_DatoB210 Posted February 28, 2012 Report Share Posted February 28, 2012 Some good lines to use would be Your body is a wonderland and I want to be Alice Or I'm like pudding, I might look like crap but I'll suffice if you're wanting some sugar. 1 Quote Link to comment
flatcat19 Posted February 28, 2012 Report Share Posted February 28, 2012 Some good lines to use would be Your body is a wonderland and I want to be Alice Or I'm like pudding, I might look like crap but I'll suffice if you're wanting some sugar. :lol: Hawaii's greenery working out for ya? Quote Link to comment
burrito213 Posted February 28, 2012 Author Report Share Posted February 28, 2012 Some good lines to use would be Your body is a wonderland and I want to be Alice Or I'm like pudding, I might look like crap but I'll suffice if you're wanting some sugar. You're seriously going to post this shit?.. dude... that's not even funny... I'm past the point of taking a joke... you are an asshole! I don't go out there jacking up peoples thread seeking information. You shouldn't either. Quote Link to comment
wayno Posted February 28, 2012 Report Share Posted February 28, 2012 Hey burrito, I just use nissan 720 brake lines usually, if I need a SAE threaded fitting, I just cut the metric stuff off, put the SAE fitting on the metric line and double flare the end of it. To me they are the same size line, the fittings have the same amount of play, and I have had no issues at all. I think the biggest thing to keep in mind is, take your time and do it right, don't get mad if you make a mistake, have a plan, and focus on one line at a time, have your brake master cylinder installed before you do the lines. When you start to flare the ends of the tubing, there is a fitting that you put in the end of the tube to start the flare, when you pull that part off the tube, do not pull it side to side to remove it from the tubing, twist and pull strait away, any other way will break that part of the flairing tool. If you need any help with the line fabrication, just call me, every vehicle I own has brake lines I have made except for the mini, and I have done it so many times, I can walk you threw it over the phone. Quote Link to comment
burrito213 Posted February 28, 2012 Author Report Share Posted February 28, 2012 what size are the 720 brake lines? i would like to play with my old lines (cutting a piece off and trying a double flare) but it doesnt look too hard to make a double flare. nothing like you tube to help the situation out. and thank you Wayno. i am sure there is at least someone else that is curious to know "how to" on doing there own lines. i will shoot you a pm or call if i run into any issues. ;) Quote Link to comment
