OldSkool Posted February 22, 2012 Report Share Posted February 22, 2012 Ive searched and I really didnt find much. The question is when do you have to use a spray bar? Does it go by cam specs, HP, or how much RPM? If you guys suggest one based solely off of cam specs, what kind of cam specs would need the use of a spray bar? BTW, this is more geared to a hot street motor. Not a full race motor Thanks Quote Link to comment
banzai510(hainz) Posted February 22, 2012 Report Share Posted February 22, 2012 get a KA or turbo 280zx oil pump. depends on cam specs and if manufacture reccomends them. Quote Link to comment
OldSkool Posted February 23, 2012 Author Report Share Posted February 23, 2012 The cam is a Isky z-196. Im not sure if I need to run a spray bar. Id rather just get a really nice oil pump. But if I have to run one then whatever.710196 Z-196 LC-263 COMPETITION 51-75 75-51 .530 .010 306° 264° A 710127 Quote Link to comment
datsunaholic Posted February 23, 2012 Report Share Posted February 23, 2012 The spray bar is only needed IF the cam isn't drilled for oiling the lobes. All factory 4-cyl ones were, but some aftermarket ones aren't. I have one that is drilled but the end isn't plugged, so until I find a way to plug it I can't use it. Basically the stock design used a hollow camshaft that got its oil from the cam towers. Since the cam was hollow, drilled passages passed oil from the towers through the cam and out the holes in the backside of the cam lobes, which oils the cam followers. The spray bar is used to oil the lobes externally. Useful on a race engine that sees constant high RPMs as the oil would get slung off too easily via the oiler holes. From what I've read, early 6-cyl L-series didn't have drilled lobes and HAD to use the spray bar, but sometime mid 70s they changed that. All 4-cyls were internally oiled from the get-go. Quote Link to comment
banzai510(hainz) Posted February 23, 2012 Report Share Posted February 23, 2012 BTW, this is more geared to a hot street motor. Not a full race motor COMPETITION 51-75 75-51 .530 .010 306° 264° A I dont think this would be considered a Hot Steet cam unless yo got a really Low gear ratio. this would be more road race super High rpm. Quote Link to comment
ggzilla Posted February 23, 2012 Report Share Posted February 23, 2012 Here is the word directly from Nissan Competition: Spray bars should be installed on any Datsun L-series 4-cylinder engines used for competition purposes. They must be installed when utilizing the #196, #273 race camshafts or any cam gound on the unground cam billet (99996-D1029). Quote Link to comment
OldSkool Posted February 25, 2012 Author Report Share Posted February 25, 2012 Thanks for all the replies guys. I need to source a spray bar setup. Quote Link to comment
Boaty Posted February 25, 2012 Report Share Posted February 25, 2012 That is a very hot camshaft, btw. Quote Link to comment
Dirttrack510 Posted February 25, 2012 Report Share Posted February 25, 2012 Not to thread jack ya, but who is making Oil Spray Bars now? I have an L4 ISKY racing cam going in my race engine. That's .580 lift baby :thumbup: Quote Link to comment
datsun510 Posted February 25, 2012 Report Share Posted February 25, 2012 Don at Design Products (714)892-1513 in Huntington Beach, Ca. He made them for Datsun Comp. Quote Link to comment
ZackTheImpaler Posted February 25, 2012 Report Share Posted February 25, 2012 I've heard of guys modifying later z car spray bars, but I've been wondering about it myself. Quote Link to comment
banzai510(hainz) Posted February 25, 2012 Report Share Posted February 25, 2012 nissan still listed them 100bucks I think it was. see it on a nismo site also.somebody knows. I think Baz in Austraila says he doesnt use them at all so research what is really needed. found it 99996-D11087 anytime its a motorsport part you need to add a M - then the part number in to nissanparts.cc.Hopefully you knew this already from olddatsuns.com in the parts /tech section made it EZ for you http://www.nissanparts.cc/cart/?pn=m-99996-D1087 I persoanlly think its a thing that can work its self loose, but thats just me or the oil line breaks Quote Link to comment
OldSkool Posted February 25, 2012 Author Report Share Posted February 25, 2012 nissan still listed them 100bucks I think it was. see it on a nismo site also.somebody knows. I think Baz in Austraila says he doesnt use them at all so research what is really needed. found it 99996-D11087 anytime its a motorsport part you need to add a M - then the part number in to nissanparts.cc.Hopefully you knew this already from olddatsuns.com in the parts /tech section made it EZ for you http://www.nissanpar...n=m-99996-D1087 I persoanlly think its a thing that can work its self loose, but thats just me or the oil line breaks Thanks for the link/part number. THATS what ive been looking for! LOL. I couldnt seem to find any info on them, and I wasnt even sure if they were made anymore. Quote Link to comment
Dirttrack510 Posted February 26, 2012 Report Share Posted February 26, 2012 Is the KA pump a direct bolt in on the L series? Quote Link to comment
banzai510(hainz) Posted February 26, 2012 Report Share Posted February 26, 2012 Is the KA pump a direct bolt in on the L series? Yes Datzenmike as show the photos a 1000 times already on the rotor size of the housing which is bigger. He has the years mentions some where as its the 1st gen KA motors 86-90 D21 Z24i Quote Link to comment
