bryant2482 Posted February 20, 2012 Report Share Posted February 20, 2012 i need a 5 speed transmission for my 85 720. send me your price and a pic Link to comment
datzenmike Posted February 20, 2012 Report Share Posted February 20, 2012 2wd not 4x4, right? 26" or 31.5" long? Gas not diesel, right? Link to comment
bryant2482 Posted February 20, 2012 Author Report Share Posted February 20, 2012 2wd not 4x4, right? 26" or 31.5" long? Gas not diesel, right? 2wd gas/z24 i believe its 26" Link to comment
bryant2482 Posted February 20, 2012 Author Report Share Posted February 20, 2012 2wd gas/z24 i believe its 26" hey mike do you know if theres a difference in gear ratios between a 76 and 85 5 speed for the 720's? Link to comment
datzenmike Posted February 20, 2012 Report Share Posted February 20, 2012 5 speeds were an option on the 620 starting at the beginning of the '77 model year, so if you have one in a '76 it was put there and no easy way to tell what it has inside. 620 and 720 truck 5 speeds came with two sets of ratios that I call wide and mid. There is a close ratio set used in the 280zx that could be used but wasn't available on the trucks. The 4 speeds also came with these two different sets. So very simplified the 4 and 5 speeds were the same gearing but with an overdrive 5th gear added. WIDE RATIO 1st.... 3.592 2nd... 2.246 3rd.... 1.415 4th.... 1.000..... 4 speeds stop here 5th.... 0.882 With a 3.592 first gear this helps multiply the torque for take offs on an incline with a heavy load. Specially needed with the lower torque L20B. This ratio is used in the '79 620 with the 4.11 and the '80 720 2wd with the 3.889 rear end. All year 720 4x4s and diesel pick-ups use the wide ratio. MID RATIO 1st.... 3.321 2nd... 2.077 3rd.... 1.308 4th.... 1.000.... 4 speeds stop here The '76 would have this 5th.... 0.833 Used with all '77-'78 620 and '81 and up 2wd 720s. The '77-'78 had a 4.375 rear axle and the 720s after '81 had larger motors with much more torque so the mid ratio could be used on these. Link to comment
bryant2482 Posted February 20, 2012 Author Report Share Posted February 20, 2012 5 speeds were an option on the 620 starting at the beginning of the '77 model year, so if you have one in a '76 it was put there and no easy way to tell what it has inside. 620 and 720 truck 5 speeds came with two sets of ratios that I call wide and mid. There is a close ratio set used in the 280zx that could be used but wasn't available on the trucks. The 4 speeds also came with these two different sets. So very simplified the 4 and 5 speeds were the same gearing but with an overdrive 5th gear added. WIDE RATIO 1st.... 3.592 2nd... 2.246 3rd.... 1.415 4th.... 1.000..... 4 speeds stop here 5th.... 0.882 With a 3.592 first gear this helps multiply the torque for take offs on an incline with a heavy load. Specially needed with the lower torque L20B. This ratio is used in the '79 620 with the 4.11 and the '80 720 2wd with the 3.889 rear end. All year 720 4x4s and diesel pick-ups use the wide ratio. yea cuz i got my 5 speed off a 76 620 and its all fucked up. MID RATIO 1st.... 3.321 2nd... 2.077 3rd.... 1.308 4th.... 1.000.... 4 speeds stop here The '76 would have this 5th.... 0.833 Used with all '77-'78 620 and '81 and up 2wd 720s. The '77-'78 had a 4.375 rear axle and the 720s after '81 had larger motors with much more torque so the mid ratio could be used on these. yea cuz i got my 5 speed off a 76 620 and its all fucked up. even after being rebulit! so the mid would be better for gas mileage? Link to comment
ggzilla Posted February 20, 2012 Report Share Posted February 20, 2012 Gas mileage is affected more by the rear end gearing than the by the overdrive gearing. But .833 is better than .882 for fuel economy. The downside is a higher first gear. The differential gearing has even a bigger spread and affects all gears. Also you need to consider the tires you have fitted. Very tall tires will upset the gearing of the truck. Link to comment
bryant2482 Posted February 21, 2012 Author Report Share Posted February 21, 2012 Gas mileage is affected more by the rear end gearing than the by the overdrive gearing. But .833 is better than .882 for fuel economy. The downside is a higher first gear. The differential gearing has even a bigger spread and affects all gears. Also you need to consider the tires you have fitted. Very tall tires will upset the gearing of the truck. ok yea cuz ive still got the stock wheels Link to comment
bryant2482 Posted February 21, 2012 Author Report Share Posted February 21, 2012 2wd not 4x4, right? 26" or 31.5" long? Gas not diesel, right? do you have a 5 speed for sale? Link to comment
troyt Posted March 1, 2012 Report Share Posted March 1, 2012 I've got a '81 720 gas 2WD 5 speed, $100, SF Bay area, no shipping. "Good when pulled" Link to comment
bryant2482 Posted March 1, 2012 Author Report Share Posted March 1, 2012 I've got a '81 720 gas 2WD 5 speed, $100, SF Bay area, no shipping. "Good when pulled" i live in vegas, if you shipped it to me i would cover the shipping cost Link to comment
troyt Posted March 2, 2012 Report Share Posted March 2, 2012 Just a FYI, there are several reasons why I and most people won't ship large/heavy items: - to properly crate an engine or tranny, and then take it to a shipper takes several hours, and no one is willing to pay me for my time on top of the shipping expense since it usually doubles the 'pick-up' price for the part - the buyer sometimes says "that's not what I wanted" when the part arrives, and then wants the seller to take the part back - something happens in shipping and the buyer wants the seller to pay for repairs (or the seller ships a broken part and says it happened in shipping) - some buyers want to wait for the part to arrive before they pay, and then don't pay I've been through all of these more than once, that's why I no longer ship anything over $100, or that doesn't fit an an Express Mail box. Link to comment
bryant2482 Posted March 3, 2012 Author Report Share Posted March 3, 2012 Just a FYI, there are several reasons why I and most people won't ship large/heavy items: - to properly crate an engine or tranny, and then take it to a shipper takes several hours, and no one is willing to pay me for my time on top of the shipping expense since it usually doubles the 'pick-up' price for the part - the buyer sometimes says "that's not what I wanted" when the part arrives, and then wants the seller to take the part back - something happens in shipping and the buyer wants the seller to pay for repairs (or the seller ships a broken part and says it happened in shipping) - some buyers want to wait for the part to arrive before they pay, and then don't pay I've been through all of these more than once, that's why I no longer ship anything over $100, or that doesn't fit an an Express Mail box. ok yea that makes sense Link to comment
GreaseMonky Posted March 3, 2012 Report Share Posted March 3, 2012 I have one from a 81 also but its from a l20B not sure if there the same, I deal with shipping companys all the time Link to comment
datzenmike Posted March 3, 2012 Report Share Posted March 3, 2012 2wd gas/z24 i believe its 26" I have one from a 81 also but its from a l20B not sure if there the same, I deal with shipping companys all the time An L transmission won't work on the Z series motor. It's also likely too long. Link to comment
GreaseMonky Posted March 3, 2012 Report Share Posted March 3, 2012 Ok, thanks for the input mike, what are they good for? Link to comment
datzenmike Posted March 3, 2012 Report Share Posted March 3, 2012 Well your transmission is an unknown as the '81 didn't have an L20B in it. If the L20B was swapped in then so was the transmission. Unless you know exactly where it came from it's hard to say. Could be out of an '80 720 as they did have L motors, could be from a 620 or even a 280zx. Link to comment
GreaseMonky Posted March 3, 2012 Report Share Posted March 3, 2012 Just looked the truck is and 80 Link to comment
wayno Posted March 3, 2012 Report Share Posted March 3, 2012 Just looked the truck is and 80 I would like to look at your 1980 5 spd. transmission if you can't sell it complete, and are going to scrap it, I would like to buy the front case, as long as it is a 1980 tranny, which I can tell from one look at it. Link to comment
GreaseMonky Posted March 3, 2012 Report Share Posted March 3, 2012 The trans im gonna sell the complete Link to comment
datzenmike Posted March 3, 2012 Report Share Posted March 3, 2012 Just looked the truck is and 80 WIDE RATIO 1st.... 3.592 2nd... 2.246 3rd.... 1.415 4th.... 1.000..... 4 speeds stop here 5th.... 0.882 With a 3.592 first gear this helps multiply the torque for take offs on an incline with a heavy load. Specially needed with the lower torque L20B. This ratio is used in the '79 620 with the 4.11 and the '80 720 2wd with the 3.889 rear end. All year 720 4x4s and diesel pick-ups use the wide ratio. Link to comment
az240z Posted March 12, 2012 Report Share Posted March 12, 2012 I have a 5 speed for a 4x4. Will sell cheap. check out my old for sale thread:My link reply to az240z@hotmail.com Link to comment
