mr928 Posted January 18, 2012 Report Share Posted January 18, 2012 So I removed the vinyl floor covering as suggested and this is what I found. Not terrible but I'm guessing I should do something to stop the progression but what? I don't want to get crazy painting as I like how original the truck is. Quote Link to comment
Laecaon Posted January 18, 2012 Report Share Posted January 18, 2012 I know you say no painting... but wiring brusH it and tHen POR15 (or alternatiVe) Quote Link to comment
Laecaon Posted January 18, 2012 Report Share Posted January 18, 2012 Oops, double posted, dont do that too often. Silly Ratsun having network issues. Quote Link to comment
Eagle_Adam Posted January 18, 2012 Report Share Posted January 18, 2012 I know you say no painting... but wiring brusH it and tHen POR15 (or alternatiVe) X2 ^^^^ i did the inside of my fender wells/inside of the fenders and the entire floor of the cab and back wall - it was simple - prep is everything Quote Link to comment
DatDoug Posted January 18, 2012 Report Share Posted January 18, 2012 :huh: That aint nuthin. Damn! Just clean that shit up & throw a Lil POR15 on it. Quote Link to comment
DanielC Posted January 18, 2012 Report Share Posted January 18, 2012 That is beautiful. This is not I am not a big fan of por15. I suggest you remove all the rust you can, by sanding, then painting with a good epoxy primer, and then an automotive paint. Once rust starts in steel, it want to feed itself. You have to remove it. If you still have the plastic floor mats, you have to pull them out, and clean under them. Dirt gets under them, and grinds the paint off the floor. Water also gets under there, and with the dirt makes a grinding compound. The plastic prevents the water from evaporating, and the rust gets going. Quote Link to comment
mr928 Posted January 19, 2012 Author Report Share Posted January 19, 2012 :huh: That aint nuthin. Damn! Just clean that shit up & throw a Lil POR15 on it. Does that have color to it? Quote Link to comment
mr928 Posted January 19, 2012 Author Report Share Posted January 19, 2012 That is beautiful. This is not I am not a big fan of por15. I suggest you remove all the rust you can, by sanding, then painting with a good epoxy primer, and then an automotive paint. Once rust starts in steel, it want to feed itself. You have to remove it. If you still have the plastic floor mats, you have to pull them out, and clean under them. Dirt gets under them, and grinds the paint off the floor. Water also gets under there, and with the dirt makes a grinding compound. The plastic prevents the water from evaporating, and the rust gets going. I did remove the mat and clean both sides of it. Quote Link to comment
RadioRedline Posted January 19, 2012 Report Share Posted January 19, 2012 Floor rust- what to do Radio Quote Link to comment
wayno Posted January 19, 2012 Report Share Posted January 19, 2012 I know you say no painting... but wiring brusH it and tHen POR15 (or alternatiVe) The above is what I would do, wire brush, then rust converter. Quote Link to comment
Daner521 Posted January 19, 2012 Report Share Posted January 19, 2012 I wish my floors looked that good! Quote Link to comment
