j72 Posted January 11, 2012 Report Share Posted January 11, 2012 what shoul i use to lower my pick up 620..any options? Quote Link to comment
MicroMachinery Posted January 11, 2012 Report Share Posted January 11, 2012 Your options are to use the search function or get flamed. Those are your options. Quote Link to comment
KC Phirus Posted January 11, 2012 Report Share Posted January 11, 2012 You need an MFB kit Multiple Fat Bitches 3 Quote Link to comment
ggzilla Posted January 11, 2012 Report Share Posted January 11, 2012 You know there's one way to redeem yourself -- post some pictures of your Datsun pickup ... The the lowering talk can continue :) Quote Link to comment
]2eDeYe Posted January 11, 2012 Report Share Posted January 11, 2012 Blocks and torsion crank, get on it :D Quote Link to comment
datzenmike Posted January 11, 2012 Report Share Posted January 11, 2012 what shoul i use to lower my pick up 620..any options? Turn the torsion bars down on the front and put a 3" block between the rear leaf springs and the axle. Changing the ride height on the front will throw the tow and camber out on the front from slightly to major. Any more lower and you may have to remove the torsion bar and reset it's spline location to give even more adjustment. The problem is that you are very close to the rubber bump stop and yes, you can cut them down for more suspension travel, but the ride quality is now affected. Riding on the bump stops is retarted. For the back, 2" or 3" blocks will space the axle higher on the body effectively lowering it that amount. The blocks and lengthened U bolts can be bought as a kit. Removing a leaf spring isalso retarted as it softens the ride and allows the body to travel further on bumps... not what you want on a lowered vehicle. All this can be found in the FAQ section of the first page of General Discussion. Quote Link to comment
j72 Posted January 11, 2012 Author Report Share Posted January 11, 2012 i'll go for blocks...all these has been such a great help,thanks to you all datsun lovers..... the MFB option was funny tho. Quote Link to comment
izzo Posted January 11, 2012 Report Share Posted January 11, 2012 i'll go for blocks...all these has been such a great help,thanks to you all datsun lovers..... the MFB option was funny tho. Good you have a sense of humor haha... You'll need it and some thick skin around here. Quote Link to comment
albyneau Posted January 11, 2012 Report Share Posted January 11, 2012 If you do decide to cut down your bumpstops for more suspension travel at the new reduced ride height, make DARN sure your shocks won't bottom out! They should have at least another inch of travel (more's better) once the bumpstop touches your suspension. It is not a pretty sight when this happens, and if you're running gas-charged shocks each one can be a little bomb under your car/truck~ with the potential of taking out a brake line, a tire, or.... Choose wisely... Quote Link to comment
DRIVEN Posted January 11, 2012 Report Share Posted January 11, 2012 I believe Pinto shocks can be used as a shorter replacement. Quote Link to comment
izzo Posted January 11, 2012 Report Share Posted January 11, 2012 I believe Pinto shocks can be used as a shorter replacement. They can. You have to remove a metal bushing from the bottom. Its kind of a PITA (ask me how i know...) Though, with a pinto shock its barely any shorter. half inch i think?? But for 13 bucks for two why not eh! Bought mine off rockauto for that shipped. Best to just add a few inches to your shock mount for ride+safety quality. Quote Link to comment
nismo dr Posted January 12, 2012 Report Share Posted January 12, 2012 They can. You have to remove a metal bushing from the bottom. Its kind of a PITA (ask me how i know...) truth! Quote Link to comment
