shootdang Posted December 23, 2011 Report Share Posted December 23, 2011 wife wants her wagon to sit a little higher in the front which is cool with me... anybody know of a spacer kit ? thanks Quote Link to comment
Sinnful Posted December 23, 2011 Report Share Posted December 23, 2011 As in, sitting higher than stock??? Quote Link to comment
FiveTenzo Posted December 23, 2011 Report Share Posted December 23, 2011 picture? Quote Link to comment
thisismatt Posted December 23, 2011 Report Share Posted December 23, 2011 A spacer for what? Just get longer and/or stiffer springs. Quote Link to comment
RedBanner Posted December 23, 2011 Report Share Posted December 23, 2011 How much higher, and why, I actuly have a set of 2" spacers for the top hats, not the best way to doit tho. Quote Link to comment
ggzilla Posted December 24, 2011 Report Share Posted December 24, 2011 coil spring spacers make it ride terrible. You can order them at Autozone or other parts store. Putting stock uncut springs back on is the best way. Quote Link to comment
philcas1987 Posted December 24, 2011 Report Share Posted December 24, 2011 on the top hat you can remove the studs then space it with washers and run longer bolts. the cheapest way. the strut insert can only extend so far. running longer springs would preload it. extending the strut tube then running spacers in the inserts with longer springs would do it. why would you want to lift it up? they ride way to high factory :P Quote Link to comment
RedBanner Posted December 24, 2011 Report Share Posted December 24, 2011 on the top hat you can remove the studs then space it with washers and run longer bolts. the cheapest way. the strut insert can only extend so far. running longer springs would preload it. extending the strut tube then running spacers in the inserts with longer springs would do it. why would you want to lift it up? they ride way to high factory :P x2, is it slammed now or stock hieght? Going for that no motor stance? Quote Link to comment
hobbes_the_cat Posted December 25, 2011 Report Share Posted December 25, 2011 ^^^They call that tugboat stance. :) Quote Link to comment
ggzilla Posted December 25, 2011 Report Share Posted December 25, 2011 I cannot imagine anyone thinking stock height needs raising. It's more likely to be a lowered 510, which some people hate when they scrape on driveways and speed bumps. I can see someone asking that to be raised up. Quote Link to comment
shootdang Posted December 28, 2011 Author Report Share Posted December 28, 2011 thanks for the replies but no its not stock and i know that there are many ways to fix the problem just a spacer lift would be the best quickest option at the time... so thanks for the input ill post pics soon im in the middle of paint right now Quote Link to comment
datsundan Posted December 31, 2011 Report Share Posted December 31, 2011 Do you have rca's on the car already? If not maybe a pair of those could possible add an inch... Quote Link to comment
ggzilla Posted December 31, 2011 Report Share Posted December 31, 2011 What's an RCA? Quote Link to comment
Laecaon Posted December 31, 2011 Report Share Posted December 31, 2011 What's an RCA? Roll Center Adjuster Also called Bump steer spacer Quote Link to comment
hobbes_the_cat Posted January 1, 2012 Report Share Posted January 1, 2012 Adding RCAs will not affect ride height. It changes geometry of the suspension to compensate for lowered cars but will change nothing about how high it sits. Quote Link to comment
