BillM Posted December 8, 2011 Report Share Posted December 8, 2011 Wanted- shifter & clutch fork for 210 transmission Bill 206-947-0107 Link to comment
Dime Dave Posted December 8, 2011 Report Share Posted December 8, 2011 Bill, The shifter doesn't have to be from a 210, any shifter from a "B" type transmission will fit the 210 transmission, it is just the bends in the lever may put the knob in a strange position especially if you put a P/U lever in a Z car. Also invest in new shifter bushings too. Brass are better as the plastic ones can get pretty beat-up. Link to comment
BillM Posted December 8, 2011 Author Report Share Posted December 8, 2011 Thanks but those are hard to find too! I have a couple of B210 shifters but they don't fit the 210 trans. Link to comment
ggzilla Posted December 8, 2011 Report Share Posted December 8, 2011 Which transmission do you have? Shifters * 56-series and 60-series interchange, including B210 4-speed. There are various bends. * 63-series is different. Clutch Fork * 63, 60, and 56 series all differ Link to comment
BillM Posted December 8, 2011 Author Report Share Posted December 8, 2011 -56 & -60 but need -60 stuff Link to comment
ggzilla Posted December 8, 2011 Report Share Posted December 8, 2011 Correction: The clutch release fork is the same 56-series and 60-series (LHD). 4spd & 5spd the same. Only the 63-series fork (B210 5-speed) differs. Link to comment
az_rat210 Posted December 9, 2011 Report Share Posted December 9, 2011 Thanks but those are hard to find too! I have a couple of B210 shifters but they don't fit the 210 trans. I have an FS5W60A out of a 210 and am using the shifter from my B210 4-Speed tranny just fine. I used brass bushings for a Z-Shifter on it, just had to file down some of the cap area to allow enough clearance for the shifter to slot in. Link to comment
Ranman72 Posted December 9, 2011 Report Share Posted December 9, 2011 Wanted- shifter & clutch fork for 210 transmission Bill 206-947-0107 I should have both those parts but I wont be home to check till friday night you need them for a 60 series tranny correct I would like 40 for both parts plus shipping let me know Thanks Randy 1 Link to comment
BillM Posted December 9, 2011 Author Report Share Posted December 9, 2011 Ranman72 Tell me how much with shipping and your address! Bill Link to comment
rbastedo Posted February 16, 2012 Report Share Posted February 16, 2012 Bill, The shifter doesn't have to be from a 210, any shifter from a "B" type transmission will fit the 210 transmission, it is just the bends in the lever may put the knob in a strange position especially if you put a P/U lever in a Z car. Also invest in new shifter bushings too. Brass are better as the plastic ones can get pretty beat-up. Reviving this thread, I am not clear on which shifters fit what. It seems you are saying a B210 shifter will also work in a 210? I know a 4 speed trans shifter from a 210 will fit and work in the 5 speed also as I have done that. So - what works where? Does a 63 series shifter work in a 210 60 series trans? Does a 56 series shifter work in a 60? Link to comment
datzenmike Posted February 16, 2012 Report Share Posted February 16, 2012 Too interesting..... I test fit a B type shifter onto my 63A dogleg and it fit. I compared the pin and bushings on all the B-210 and 210 4 and 5 speeds. The plastic bushings are all the same part number. The shifters themselves may be all different lengths and bends but the pin and bushings should be a good indication that they will fit... sort of. The FS5W63A dogleg shift pin is identical to the 56A 4 speed pin. The following have the same pin number but does not match the dogleg. F4W60 4 speed in the B-210 and the 210 FS5W60L dogleg in the 210 FS5W60A in the 210 Link to comment
