Phixius Posted November 9, 2011 Report Share Posted November 9, 2011 Test fitted some supercharged xterra wheels on the 521 today. 17x8 et40 here are the findings so far.. Fronts with just the rim without tires. Any tire size suggestions? Hits the swaybar when turning left and the brake lines turning right. and the rears.. Hits the frame and spring perch. Not sure if its hitting more on the perch or the frame. the gap. So Ive learned that s/c xterra wheels dont just bolt right up... spacers, grinding, bending... EDIT: Should this be under the wheels tires section? Quote Link to comment
socaldatsun Posted November 9, 2011 Report Share Posted November 9, 2011 You could probly just solve it buy getting longer studs and 1" spacer? they look prety sick man, whats the offset? Quote Link to comment
yello620 Posted November 9, 2011 Report Share Posted November 9, 2011 Those are never going to work. Probably better send them my way. :D Ya, its going to take some work to make those fit. Quote Link to comment
Phixius Posted November 9, 2011 Author Report Share Posted November 9, 2011 You could probly just solve it buy getting longer studs and 1" spacer? they look prety sick man, whats the offset? 17x8 et 40 Quote Link to comment
Phixius Posted November 9, 2011 Author Report Share Posted November 9, 2011 Those are never going to work. Probably better send them my way. :D Ya, its going to take some work to make those fit. There on there way to whomever sells me the right/best tire size for the cheapest... Quote Link to comment
jrock4224 Posted November 10, 2011 Report Share Posted November 10, 2011 just use some washers to determine the amount of spacing your need then have them cut out ....or just run the weashers i here they produce some sweet wheel shake...oh and my eskies rub rim on sway bar at lock and tire on inner fender ....i fixed this by not turning as sharp....my lazy ass shold probably readjust the steering stops at some point ... Quote Link to comment
jrock4224 Posted November 10, 2011 Report Share Posted November 10, 2011 215-40-17...i run 205s on my 17's there fine... Quote Link to comment
jrock4224 Posted November 10, 2011 Report Share Posted November 10, 2011 oh yeah what happened to thqat civic coupe in the back ground looks like it was in a high speed chase... Quote Link to comment
stretch Posted November 10, 2011 Report Share Posted November 10, 2011 ill trade yah for the ones on my truck :D 1 Quote Link to comment
Phixius Posted May 11, 2012 Author Report Share Posted May 11, 2012 actually got around to putting these things on... To make these fit and be this low, I had to take my 4" blocks off and run 3" blocks with 720 4x4 leaf springs. 3/4" spacer and longer ARP wheel studs. While I was at it I also installed a 3.88 gear set. Quote Link to comment
mrbigtanker Posted May 11, 2012 Report Share Posted May 11, 2012 The ARP studs can you tell me the part number please and did you have to drill your hubs or are they same diameter as stock.I like the wheels and as for 17" yea you can go with a 3" block only same problem with my truck.When i put the 18" wheels in the back i could go 4" blocks.Also what tires did you stretch on those wheels.I got 7" wide all the way around and put 235 in the rear and 225 up front. Quote Link to comment
Tristin Posted May 11, 2012 Report Share Posted May 11, 2012 You can get extended studs through FutoFab as well... as long as the studs are the same diameter as 510 ones. I have a set I havent installed yet... Im thinking of doing it if/when I do rear disks. Quote Link to comment
mrbigtanker Posted May 11, 2012 Report Share Posted May 11, 2012 Thanks I will check it out futofab Quote Link to comment
jrock4224 Posted May 12, 2012 Report Share Posted May 12, 2012 tristan u are up in my peeps all over there threads.....nice job frank thanks for stopping by and showing me live .... truck looks sweet even if it took your life savings and 6 months to get those wheels Quote Link to comment
jrock4224 Posted May 12, 2012 Report Share Posted May 12, 2012 holy shit your 240, that is in the waste high grass, in the back ground is a rb 26 tt... and its sitting in the grass why? i wont even get into the 510 issues and why its not running or legal Quote Link to comment
Tristin Posted May 12, 2012 Report Share Posted May 12, 2012 tristan u are up in my peeps all over there threads.....nice job frank thanks for stopping by and showing me live .... truck looks sweet even if it took your life savings and 6 months to get those wheels Just helpin' a brotha out until you show up and display your vastly superior truck knowledge :rolleyes: Quote Link to comment
jrock4224 Posted May 12, 2012 Report Share Posted May 12, 2012 Just helpin' a brotha out until you show up and display your vastly superior truck knowledge :rolleyes: ah snap i got bitched slapped by tristan....oh yeah well my dad will beat up your dad.. Quote Link to comment
mrbigtanker Posted May 12, 2012 Report Share Posted May 12, 2012 holy shit your 240, that is in the waste high grass, in the back ground is a rb 26 tt... and its sitting in the grass why? i wont even get into the 510 issues and why its not running or legal Wow i never even saw it good eye bro. Quote Link to comment
Phixius Posted May 12, 2012 Author Report Share Posted May 12, 2012 The tires are 215/40 17 on a 8" rim. The ARP studs are a 100-7701, they slide right in the stock hole, only thing you need to do is grind a flat spot on the knurl like the stock 521 stud. Jrock -- I dont know if I should even acknowledge your posts... I like how when I was standing right next to you, giving you fuel for you to bash me with, you couldent even make out your own sentences when you tried proof reading... Quote Link to comment
Tristin Posted May 12, 2012 Report Share Posted May 12, 2012 JRock always has the worst online grammar. Before I met him I thought he was mentally challenged... then I met him and knew he was mentally challenged. 1 Quote Link to comment
mrbigtanker Posted May 12, 2012 Report Share Posted May 12, 2012 The tires are 215/40 17 on a 8" rim. The ARP studs are a 100-7701, they slide right in the stock hole, only thing you need to do is grind a flat spot on the knurl like the stock 521 stud. Jrock -- I dont know if I should even acknowledge your posts... I like how when I was standing right next to you, giving you fuel for you to bash me with, you couldent even make out your own sentences when you tried proof reading... Thank you.It sure is a big help to know what i need.I need shorter but this totally puts me in the right direction. Quote Link to comment
jrock4224 Posted May 28, 2012 Report Share Posted May 28, 2012 Tristan I will give u that ..... That was funny.... Frank my grammar sucks online .....but wtf are u tryin to say .... Quote Link to comment
jrock4224 Posted May 28, 2012 Report Share Posted May 28, 2012 Oh when I had no idea wha I was trying to say when I was proofreading my post while u were standing there....what can I say I learned to type on a word processor..... And I stare at my fingers and am too Lazy to back track on my phone..... It just carries over to my computer skills ..... Ass hat Quote Link to comment
mrbigtanker Posted May 28, 2012 Report Share Posted May 28, 2012 Thanks again,i got the wheel studs just getting them machined down for my truck.thanks again Quote Link to comment
jrock4224 Posted May 30, 2012 Report Share Posted May 30, 2012 make a build thread frank....project datto Quote Link to comment
