L20b / Z22 Flywheeel interchange?
Jester
I have been holding on to this dang L20B flywheel for quite a while. It was in the back of one of my old parts trucks. Forgot how damn heavy it was. A couple weeks ago I picked up a Z22S with the flywheel. Didn't even think about the weight. Now last night I'm over at NKL DYM's and he offers we a freshly rebuilt L20B for my wagon.blink.gif Mentioned I would just need the flywheel for L20. NO PROBLEM, I HAVE ONE. I dig out this old rusty L flywheel AND I grab the Z flywheel. HOLY CRAP.....WHAT A DIFFERENCE IN WEIGHT!!!!
Check this out.
Now the L20 has three alignment pins in it
And the Z22 only has a place for two. One is gone and the other is broken off.
I am thinking of using the Z22 flywheel behind the L20 with the Z22 truck clutch. Any one see a reason this wouldn't work after I have it balanced?
  • Replies 11
shouldnt be a problem at all.
i have a 84 z24 flywheel on my 77 l20b.
i went right to the z24 flywheel from an auto trans, so i dont know if theres any difference for the driveablility.
other than that, i think you should be able to use the 240 mm nissan clutch now. use the clutch and PP from the truck the flywheel came from..
good luck man!
  • 4 weeks later...
Check this out.
If the engine side is scalloped like this it weighs about 21pounds. If it's flat across the back it's about 29 pounds. A heavy vehicle like a truck with a small L20B motor would likely have the heavier 29 pound one for storing rotating energy for take offs. Cars specially with 6 cylinders or larger Z22/24 motors might have the lighter ones.
It will work perfectly. If you were using the truck for hauling heavy loads you might notice having to rev and slip the clutch a bit more. What size clutch? 225?
