510 vs. 620 Hitachi carb.
Rockatansky620
I found a rebuilt carb on eBay, and it says its a Hitachi for a 510 but strikes an uncanny resemblance to the factory Hitachi carb on my 620. A re these interchangeable?
http://www.ebay.com/itm/130590111478?item=130590111478&viewitem=&vxp=mtr#ht_3618wt_1185
Looks like a rocking price and the seller has great feedback. This would save me the time of learning the innerworkings of a cab and let me rebuild my current one in my own time.
  • Replies 12
They are all roughly similar looking, yes. The first electric chokes were on the '72 model but made June '71 so the description is sort of right. The one shown is consistent with the '72 L16 carb. This one would not fit the 620 exactly because of the different throttle linkage. It would also be jetted for a smaller L16.
Ok, got the carb in the mail, and from what I can tell, a simple linkage swap will make this carb useable. EXCEPT, for this missing sensor on the new carb. Here are some oics of the two:
Hers the sensor with a single wire coming off of it:
Another shot:
And where it would be on the new beautiful carb:
Any idea what this sensor is? And how important it is? I'm not thinking very much considering this is a 1973 pickup.
  • 3 weeks later...
All fuel going to the idle circuit has to get past the idle cut solenoid. It's an electrically operated valve that is held open when the ignition is in the ON position allowing fuel to the idle mixture screw. Many motors have a tendency to 'diesel' or 'run on' when the key is turned off. This is caused by many things such as crappy lead free gas (that does not prevent pre ignition as well) and higher engine running temperatures. When the ignition is shut off there is enough heat and compression (and idle mixture) for the cylinder if self ignite. An idle cut solenoid stops the flow of fuel to the idle circuit when the key is turned off and quickly stalls the motor.
