Ron1200 Posted October 23, 2011 Report Share Posted October 23, 2011 When it rains, water drips from the plastic vent tubes on the end of the dash. It appears that its coming from the holes for the plungers (they open/close the vent). I searched and found nothing similar. I can't think I'm the only one to have this problem. Looking for ideas on where to start. Quote Link to comment
datzenmike Posted October 23, 2011 Report Share Posted October 23, 2011 Remove cowl behind the hood and check for leaves blocking the drain hole on each side. Quote Link to comment
Eagle_Adam Posted October 24, 2011 Report Share Posted October 24, 2011 Remove cowl behind the hood and check for leaves blocking the drain hole on each side. after this ^^^ have someone hose your truck down while you sit in it. I found my leak that way, it was the firewall grommets. Quote Link to comment
Radiant-Designer Posted October 24, 2011 Report Share Posted October 24, 2011 after this ^^^ have someone hose your truck down while you sit in it. I found my leak that way, it was the firewall grommets. It helps if they are a good looking girl in a bathingsuit ;) wait, maybe it doesnt.... you want to be looking for leaks in the truck, not checking her out.... guess i just want an excuse to see a good looking, scantily clad woman hose down my truck ;) Quote Link to comment
Ron1200 Posted October 25, 2011 Author Report Share Posted October 25, 2011 "Yeah looks like I need to hose it down... I removed the cowl to check the holes. I found them to be clear. Nothing was blocking them. Besides the vent shields that cover part of the vent opening, is there anything else in their to divert the water? It looks like something was attached under the cowl opening at some point. My 620 does not have fender liners. Could that contribute by forcing the water back into the cowl area? Quote Link to comment
datzenmike Posted October 25, 2011 Report Share Posted October 25, 2011 I doubt tire spray would force it's way in through there. Could the windshield be dripping down onto/into the vents? Quote Link to comment
Z-train Posted October 25, 2011 Report Share Posted October 25, 2011 One man leak test.Clean the area real good.Then cover it with babypowder or flour.Hose it down and the leaks will leave tracks in the powder. Quote Link to comment
Ron1200 Posted October 25, 2011 Author Report Share Posted October 25, 2011 I can see where it comes out, from the inside of the vent tubes, via the holes for the push-pull rod. This happens on both sides, right and left. So it's something common to the cowl me thinks. As I'm not even sure the cab is original to the frame, I was wondering if something got left out when it was reassembled. Like maybe a baffle. Quote Link to comment
Ron1200 Posted November 17, 2011 Author Report Share Posted November 17, 2011 Adding resolution... Just in case someone has the same issue. The leak did not come from the vents. From looking at them, It would be difficult for water entering the cowl to enter via the vents. The problem was a poor windshield gasket seal to the glass. Water would work it's way around the glass edge and flow to the corners where it would drip on the inside. Guess where... Right above the side vents. :angry: I used black RTV silicone to inject a small amount around the edges. This did the trick. :) Quote Link to comment
]2eDeYe Posted November 17, 2011 Report Share Posted November 17, 2011 Glad to hear you got it resolved :thumbup: Quote Link to comment
