L320 1 Ton?
Fogdart
New guy here....I posted this pic under a different topic today. I hadn't looked at this photo for a couple years but it brought to mind a question I had when I bought the truck. I started sanding on it a bit right after I got it and the lettering you can see on the fenders and cab became more evident. It says "DATSUN 1 TON" on both fenders and above both doors on the cab. Don't know if this was a dealership truck a one time or what but surely these little trucks were never rated for 1 ton, were they?
  • Replies 8
I beleave they were all rated 1 ton back then, they were trying to compete with full size trucks back then. Datzenmike knows all the stats on this, he published/posted the details, but I cannot remember where it is on here(ratsun).
EDIT I just looked up the 320 weight specs, and found only 1/2 ton limits, maybe datzenmike will chime in here, and post the data he has posted before, as he might remember where it is.
  • 4 weeks later...
I had to bring one of my 320s across the scales for registration and it WEIGHED on ton, exactly.
I put one ton in that same truck. No lies, it hauled 2000lbs of concrete to the dump. Man was that a scary drive.
Maybe the "one ton" was for shipping or a promotional thing, as in "this Datsun only weighs one ton" (???)
I only go back to the mid '60s 520 trucks rated at 1,000 kilograms which would be 2,200 lbs I believe. The 521 was rated at 500Kg but I wonder if the springes were actually changed or not as they also had a stif ride . I carried over 1,700 lbs on my old 521. It flattened them out.
