ariascarlos1990 Posted March 27, 2008 Report Share Posted March 27, 2008 ok so i recently purchased a AutoMeter Sport-Comp Monster and I installed it but, I had a problem. It was idling at 0 RPM's but it was reving up to like 1,000 RPM's when I gave it some gas. Its a L20B engine in a '78 Datsun 620. Do you know what could be the cause of this? thanks, Quote Link to comment
]2eDeYe Posted March 27, 2008 Report Share Posted March 27, 2008 Most aftermarket tachs come set for V8's. They have different methods of adjusting for 4 and 6 cylinders. You might read the literature for the tach you purchased. If you don't have the literature you might be able to download it from the manufacturers website. Quote Link to comment
Bleach Posted March 27, 2008 Report Share Posted March 27, 2008 or flip the switch on the back that says 4 - 6 - 8 :D I'd say "4" is where you want it Quote Link to comment
ariascarlos1990 Posted March 27, 2008 Author Report Share Posted March 27, 2008 there ident a switch one the back. But I was reading about it and it was saying that this one programs itself. I'll try downloading the program. Hopefully I can download it to my itouch because this is my only Internet source. Quote Link to comment
fiveNdime Posted March 28, 2008 Report Share Posted March 28, 2008 with my auto meter I had to clip a wire. I believe it was the orange one but.....don't do it unless it tells ya! Quote Link to comment
b210in Posted April 1, 2008 Report Share Posted April 1, 2008 dude, cut both wires and that should set it for four cylinders. if you go to autometer.com, you can down load the wiring diaghram for free. Quote Link to comment
south of reno Posted May 25, 2012 Report Share Posted May 25, 2012 Anyone know what light source wire to splice into on a 79" 210 wagon? Quote Link to comment
Laecaon Posted May 25, 2012 Report Share Posted May 25, 2012 Anyone know what light source wire to splice into on a 79" 210 wagon? This is called thread jacking and necrothreading. Anyways Unplug the instrument panel plug, and take a test light to all the wires with the lights turned on. Quote Link to comment
ggzilla Posted May 25, 2012 Report Share Posted May 25, 2012 There is an easier answer to your 210 question, but you should create a new Topic. Quote Link to comment
south of reno Posted May 26, 2012 Report Share Posted May 26, 2012 I have it hooked up to a switchable soure which is ok and stays on when i turn the car on but i was wondering which of the three wires to tap into from the panel lights dimmer switch. Quote Link to comment
Sealik Posted May 26, 2012 Report Share Posted May 26, 2012 I have it hooked up to a switchable soure which is ok and stays on when i turn the car on but i was wondering which of the three wires to tap into from the panel lights dimmer switch. ......... you should create a new Topic. Quote Link to comment
