Just Joel Posted September 19, 2011 Author Report Share Posted September 19, 2011 Amazon, $45 shipped... Later Joel Quote Link to comment
Zfighter76 Posted September 20, 2011 Report Share Posted September 20, 2011 electric fans are beast, just pick one up for like 50 bucks or less, or from a junkyard. mine was like 43 from oreillys and it works great. hooked it up to a relay along with my fuel pump so they both turn on with the ignition Quote Link to comment
Just Joel Posted September 21, 2011 Author Report Share Posted September 21, 2011 Paraut= repakaged Jap OEM Atsugi = GOOD Confirmed, atsugi with cast impeller... Thinking about ordering an extra one for a spare :P Later Joel Quote Link to comment
datzenmike Posted September 21, 2011 Report Share Posted September 21, 2011 electric fans are beast, just pick one up for like 50 bucks or less, or from a junkyard. mine was like 43 from oreillys and it works great. hooked it up to a relay along with my fuel pump so they both turn on with the ignition I agree about the electric fans but the relay should be triggered by a thermostat or they will be on all the time even when not needed. No fan is needed on a cold motor or one moving over 25 MPH as there is enough air pushed through the rad from vehicle motion. Only time it will come on is (sometimes) waiting for a green light or if sitting still long enough.. Quote Link to comment
0r0B210 Posted November 13, 2013 Report Share Posted November 13, 2013 I bought my B210 with no fan, and no fan clutch. What would I need to install a universal electric fan? Would I need the fan and the relay? What do you guys recommend. I do not want to use the flex fan because I do not want anything to happen at slow speeds (i.e. traffic, etc.). I appreciate all of anyone's input as I am a long-time Datsun lover, first time Datsun owner. 'It's Dat-time!' Peace guys. Quote Link to comment
datzenmike Posted November 13, 2013 Report Share Posted November 13, 2013 Well having an electric fan on all the time defeats it's purpose. A driver operated switch is not advisable. These things should be automatic and fool proof. Quote Link to comment
zed Posted November 13, 2013 Report Share Posted November 13, 2013 I bought a threaded T-piece with same diameter flanges as the rad pipe - from a rad shop. Bought a temp sensor (from a Fiat!) to thread into the T-piece - which is inserted in the outflow pipe of the rad. Used that to trigger the electric fan through a 30-amp relay. Also put a simple toggle switch under the dash to bypass the sensor - for when it gets above 40 here Quote Link to comment
datzenmike Posted November 13, 2013 Report Share Posted November 13, 2013 Sound perfect. Quote Link to comment
KlassicMotion Posted November 13, 2013 Report Share Posted November 13, 2013 Second, fan noise is related to blade spacing~ not the clutch (or lack thereof). Fans, just like any other rotating component, create noise. Even blade spacing introduces harmonics to that noise~ find a fan that has staggerd blades. ^That's fan blades 101 right there. :thumbup: Joel, nice find on that H2O pump! My 2 cents: I only go clutch fan, or electric on all of my vehicles. I will never go back to a fixed fan, unless it's for a restoration that needs to be concours correct. Some of those electric fans come with a thermometer you stick into the radiator core fins.... That's what I had on my '65 Mustang, and I had issues with it. I also had a fuse go bad (not a short, just a junk fuse), when I was in stop and go traffic in 90 degree temps. It took me a little bit to realize it wasn't coming on, and by that time the aluminum head was warped. I like the clutch fan on my L20B, no issues. Quote Link to comment
jovial_cynic Posted November 14, 2013 Report Share Posted November 14, 2013 Chiming in on the electric fan. Some rabbit radiators have a temp sensor built in that you can use to trigger a relay for the fan. That's how I have mine set up. Quote Link to comment
