thor Posted August 23, 2011 Report Share Posted August 23, 2011 My 521 came with packs of these bushings. Not sure what they are for. Any thoughts? Quote Link to comment
420n620 Posted August 23, 2011 Report Share Posted August 23, 2011 look to be for the sway bar, bolts. Quote Link to comment
Ranman72 Posted August 23, 2011 Report Share Posted August 23, 2011 cant tell size from the pic maybe leaf spring ends Quote Link to comment
ggzilla Posted August 23, 2011 Report Share Posted August 23, 2011 Body mount bushings? Quote Link to comment
thor Posted August 23, 2011 Author Report Share Posted August 23, 2011 They are about an 1" in dia and came in a Nissan bag part # 56112-09400. there's 2 bags with 10 in each lol Quote Link to comment
motavated Posted August 23, 2011 Report Share Posted August 23, 2011 8 OF THEM GO ON THE BARS FROM THE ARMS TO THE BODY. Quote Link to comment
motavated Posted August 23, 2011 Report Share Posted August 23, 2011 see those bars? They belong on there... Quote Link to comment
motavated Posted August 23, 2011 Report Share Posted August 23, 2011 They can be used on sway bar end links and shock bushings as well... Quote Link to comment
thor Posted August 23, 2011 Author Report Share Posted August 23, 2011 Oh so they are control arm bushings? Or on the radius arms? Quote Link to comment
420n620 Posted August 23, 2011 Report Share Posted August 23, 2011 the rods that motavated is refering to are called tension bars, they keep the lower control arms from moving forward or backwards. Quote Link to comment
ggzilla Posted August 23, 2011 Report Share Posted August 23, 2011 56112-09400 is used by tons of datsuns all the way from 1960s to 1980s. The the 1200 sedan it is the shock absorber bushing for the rear shocks. Quote Link to comment
thor Posted August 23, 2011 Author Report Share Posted August 23, 2011 the rods that motavated is refering to are called tension bars, they keep the lower control arms from moving forward or backwards. Ok yea I've always called those radius arms. Thanks guys new you were the ones to ask! Quote Link to comment
ggzilla Posted August 23, 2011 Report Share Posted August 23, 2011 On the 620, the bushings are used for the anti-swaybar (stabilizer bar). 4 on each side, eight total. The tension rod bushings are 54481-18000 (for older 620s) and 56127-25660 (for disk brake 620s) Quote Link to comment
datzenmike Posted August 23, 2011 Report Share Posted August 23, 2011 They are about an 1" in dia and came in a Nissan bag part # 56112-09400. there's 2 bags with 10 in each lol Probably fit the 520/521 but they definitely are the correct number for the 620 sway bar. Ooops, also the 510,610,710, S10, A10, z and zx cars Quote Link to comment
ggzilla Posted August 23, 2011 Report Share Posted August 23, 2011 Part numbers - Ratsun Forumscommunity.ratsun.net/topic/4131-part-numbers Last post: Jul 31 sway bar bushings 56112-09400 Quote Link to comment
