oldschool80sguy Posted September 19, 2011 Author Report Share Posted September 19, 2011 working with some mockups and trying some paint schemes. will get some orange and or green to add to the back panel to judge the cut-out. Quote Link to comment
Zfighter76 Posted September 19, 2011 Report Share Posted September 19, 2011 To clear up an earlier point; Here are the two cross-members side by side. at first glance you can see the LCA points and engine mounting area are identical. when i took a closer look i noticed that other than the goofy bar in-between there is only one other difference. There seem to be a second Control arm stud location custom drilled above the stock one. what this does exactly to the suspension or the wheel location i am not sure. the holes that are drilled above the stock ones, i believe, would be to level out the lca when the car is lowered. this improves suspension geometry by keeping the arm level, helps roll or something like that. again this is a guess but if its going to be low, i would try it in both positions to see if theres a difference Quote Link to comment
oldschool80sguy Posted November 8, 2011 Author Report Share Posted November 8, 2011 Quote Link to comment
oldschool80sguy Posted November 12, 2011 Author Report Share Posted November 12, 2011 I only wish my car was possessed like "Christine" So that it would repair itself. Quote Link to comment
oldschool80sguy Posted November 12, 2011 Author Report Share Posted November 12, 2011 Quote Link to comment
VintageRice Posted December 23, 2011 Report Share Posted December 23, 2011 I do want to build a VG33 but i never considered boring it. sounds mean. My goal is to make over 175 horse. sounds do-able. I have no plans to smoke every car on the street. I just want a reliable engine that will get me to the car nights and let me do a burn out every once in awhile. if i go VG33 i am def carbing it. :cool: Yessssssssss. Quote Link to comment
oldschool80sguy Posted January 20, 2012 Author Report Share Posted January 20, 2012 Quote Link to comment
oldschool80sguy Posted January 31, 2012 Author Report Share Posted January 31, 2012 Carrera rear Coil-overs Quote Link to comment
oldschool80sguy Posted February 10, 2012 Author Report Share Posted February 10, 2012 1 Quote Link to comment
oldschool80sguy Posted February 13, 2012 Author Report Share Posted February 13, 2012 Rear mostly together. waiting on R160 Gasket or whatever and coil overs to be rebuilt. wheels are being straightening and cleaned up for PC. Quote Link to comment
oldschool80sguy Posted February 27, 2012 Author Report Share Posted February 27, 2012 Well, we all cant have our dream engine the first time up and i could not pass on such a great deal from another 510 owner. this bad boy will bolt right up and has 0 miles. NAPz 2.4 Ported/polished Port matched HKS manifold Dual mikunis/Solex 44's fully rebuilt Custom oil pan. I stripped her, cleaned her, repainted her and checked tolerances. 1 Quote Link to comment
fuzz's '71 510 Posted February 27, 2012 Report Share Posted February 27, 2012 Did you happen to sale the spare tire well?? PM me if you would be interested in shipping it out and how much. Fuzz Quote Link to comment
oldschool80sguy Posted March 22, 2012 Author Report Share Posted March 22, 2012 Funny note: make sure you know what rear end you have before you purchase a gasket. found out that i do not have an R160 LSD 3.90. turns out i have an R180 LSD 3.90. LOL were getting ready to put everything in and then i hold the gasket up and its obvious something is amiss. I permatexed it for now. Quote Link to comment
oldschool80sguy Posted April 8, 2012 Author Report Share Posted April 8, 2012 working with rear. The Carrera were fully rebuilt, anodized black and spring Agean blue to match the 280 coil overs i made upfront. Half Shafts sandblasted. Quote Link to comment
oldschool80sguy Posted April 21, 2012 Author Report Share Posted April 21, 2012 I Commited to the color today and purchased my paint. Synergy Green Metallic. 2 Quote Link to comment
Z chopper Posted April 21, 2012 Report Share Posted April 21, 2012 Synergy Green is one of my favourites that has came out in recent years 1 Quote Link to comment
Z chopper Posted April 22, 2012 Report Share Posted April 22, 2012 gotta see what Synergy Green looks like on a 510 as it is one of the colours I am thinking of for the 510 I am picking up tomorrow Quote Link to comment
oldschool80sguy Posted April 25, 2012 Author Report Share Posted April 25, 2012 some other progress. currently i am working with friends to get some take off wheels so i can move forward with paint and body. had to weld two washers on side of shifter to make the rectangle cut out fit the NAPz trans. all gravy now, and the laid back curve design will help bring the shifter knob back a few inches from this short tranny. Spacers to fit almost any shock. New Seat rails out of 1x3 Square pipe. welded to frame rails/door sills/trans tunnel MR2 Seat in place rather nicely, enough room for an adult to get in back. Washers on shifter mount. Quote Link to comment
oldschool80sguy Posted April 26, 2012 Author Report Share Posted April 26, 2012 Raining out so i turned on Rocky 4 and worked on my cluster as per The Dime Quarterly Volume: 5 Issue: 2. not many pics on the step by step but so far so good. looking into how i can get my odometer back to "0000000" since my engine is in essence new. hmmm, cordless drill and bit? (notice the broken circuit, gonna have to jumper that path) Quote Link to comment
bonvo Posted April 26, 2012 Report Share Posted April 26, 2012 looking aat that rear x member it looks like it has points to join to a cage is that the case? Quote Link to comment
oldschool80sguy Posted April 26, 2012 Author Report Share Posted April 26, 2012 looking aat that rear x member it looks like it has points to join to a cage is that the case? In short, Yes. The car has full length frame rails running in line with the car. they attach to the rear X member vial two squar pipe posts, allowing for the X member to still be removed on its own. so it has the stock mateing points....Um 4 right? the 2 huge ones, and the two smaller diff supports +2 from my frame rails. I actually hope the car isn't too too stiff. Quote Link to comment
bonvo Posted April 26, 2012 Report Share Posted April 26, 2012 take some pics thats something i have been considering for a while Quote Link to comment
Tristin Posted April 27, 2012 Report Share Posted April 27, 2012 This is completely off-topic, but I just scoped out this thread and saw you were in the Navy... Whats your rate? Quote Link to comment
