dat521gatherer Posted July 3, 2011 Report Share Posted July 3, 2011 My wife and I bought this the other day. I'm still test driving it to see what bugs need to be worked out. We bought it so our daughter can get some driving experience but it's growing on us adults quickly. The to do list will be posted soon with lots of questions. all comments and help welcome. Let the PICS begin. 1 Quote Link to comment
Siqx20 Posted July 3, 2011 Report Share Posted July 3, 2011 How about u dont give it to your daughter and u sell it to me!! i will even throw in a honda crx that is my dd she can drive that ;) 1 Quote Link to comment
Jayden71 Posted July 3, 2011 Report Share Posted July 3, 2011 That thing is SAWEET!!!!! :cool: :cool: :cool: Quote Link to comment
RedBanner Posted July 3, 2011 Report Share Posted July 3, 2011 well done, thats a good one :D Quote Link to comment
ggzilla Posted July 3, 2011 Report Share Posted July 3, 2011 First year of the A14! What is that switchgear to the right of the steering column? Quote Link to comment
RedBanner Posted July 3, 2011 Report Share Posted July 3, 2011 intermetin wipers¿? maybe somthing to do with the ac, maybe its got a gear vender :D Quote Link to comment
dat521gatherer Posted July 3, 2011 Author Report Share Posted July 3, 2011 a/c. It doesnt work and I'm not sure it ever will considering it takes the old refrigerant. Quote Link to comment
420n620 Posted July 3, 2011 Report Share Posted July 3, 2011 if your daughter needs driving experience, buy a Toyota or Honda. Once she can prove to you and the wife that she is a good & a responsible driver, then give her the Datsun. I gave my daughter a 74 710 2dr orange w/ blk vinyl top, low mileage, 4 speed, non-smoker car for her 1st car and she ended up rearended a BIG YELLOW school bus. How in the hell did she not see a BIG YELLOW school bus, Oh she was waving at some friends. I learned a lesson there but so did she, I grounded her from driving any of our vehicles forever and sold the car. remember, Datsuns are to be driven but also saved from the scrapper. my 2cents 1 Quote Link to comment
Dguy210 Posted July 3, 2011 Report Share Posted July 3, 2011 a/c. It doesnt work and I'm not sure it ever will considering it takes the old refrigerant. There are a couple of ways you can get this working, and getting the license to buy R12 is actually pretty easy. There are also some almost drop-in "alternative" refrigerants available (cheaper than R12). If the compressor is good probably ~200-300$ to get running, maybe a little less. If the compressor is shot more like ~400$. Or you can just remove all the A/C stuff and sell it to me Quote Link to comment
dat521gatherer Posted July 3, 2011 Author Report Share Posted July 3, 2011 if your daughter needs driving experience, buy a Toyota or Honda. Once she can prove to you and the wife that she is a good & a responsible driver, then give her the Datsun. I gave my daughter a 74 710 2dr orange w/ blk vinyl top, low mileage, 4 speed, non-smoker car for her 1st car and she ended up rearended a BIG YELLOW school bus. How in the hell did she not see a BIG YELLOW school bus, Oh she was waving at some friends. I learned a lesson there but so did she, I grounded her from driving any of our vehicles forever and sold the car. remember, Datsuns are to be driven but also saved from the scrapper. my 2cents Yeah she wont be driving it by herself anytime soon. Only with mom or dad in the car. At this point the datsun bug has bit my wife with this car. They just went up to the car wash and they bickered and my wife won. She wants to drive it to work already. Besides, insurance for her to drive it by herself is way too expensive. Quote Link to comment
dat521gatherer Posted July 3, 2011 Author Report Share Posted July 3, 2011 Ok I bought the haynes and chilton manual. The factory nissan is on the way in the mail.THINGS TO DO-1 Lube door hinges. One has a bad flat spot that makes the door not want to shut. lube now fix later.---Done2 Fix the horn. I hear the relay and a faint sound from the horn. steering wheel contacts?---fixed, bought horns--Done3 Muffler is rattling. Should I remove the cat if its there?---no cat but has a pre muffler.---Done4 Gauges work sometimes, probably a loose con. I dont see a gauge volt reg on the back cluster.---Done5 Check timing and dwell---Done6 Unplug left wiper squirter---Done7 Study and reroute vacuum lines. lots of missing and blocked lines.---Done8 Study and fix carb wires.---swapped 4 weber---Done9 Fix flat spot in carb---swapped 4 webber---Done10 Shine rims and find center caps to buy---DoneTHINGS TO BUY---1 Dome light with housing---Done2 Rear view mirror---Done3 Rear hatch shocks.---Done4 Heater hose---need long one really bad---Done5 Fusebox---bought6 Brake booster7 Rear shocks---Done8 Find a stock fm radio---Done9 Hood bumpers---Done10 Left tail light---Done11 Owners manual---Done12 Coil boot---DoneSpecific pics and questions coming soon. Thanks guys. Quote Link to comment
ggzilla Posted July 4, 2011 Report Share Posted July 4, 2011 The instrument panel voltage regulator is integral with the temperature gauge. It also regulates the fuel gauge. Quote Link to comment
dat521gatherer Posted July 6, 2011 Author Report Share Posted July 6, 2011 I need a anti dieseling solenoid. The wire is not repairable. Can I use one off my l16 hitachi dhc328? or dhc340? I cant find the part numbers to compare. It does idle fine without it hooked up. I'm hoping a anti die-sol will fix the flat spot it has when stepping on the gas lightly. I'll also clean out the 2 jets under the bowl. My choke wire has no power. Where is the choke relay? Is it under that mysterious black box next to the coil? I cant find its location in my manual. How important is the throttle opener system? Mine is disconnected and the servo diaphram hose is going to the bottom of the carb instead of the throttle opener solenoid. should I leave it like this meaning does it work being there or can I remove the throttle opener system as in the control valve and solenoid? Quote Link to comment
ggzilla Posted July 6, 2011 Report Share Posted July 6, 2011 Anti-diesel solenoid won't fix a flat spot. The only thing it fixes is possible dieseling. If the engine idles OK with the solenoid not hooked up, it is because someone removed the pintle from the solenoid. In that case, you DON'T need to replace it, it won't make it run any better. Quote Link to comment
dat521gatherer Posted July 6, 2011 Author Report Share Posted July 6, 2011 Anti-diesel solenoid won't fix a flat spot. The only thing it fixes is possible dieseling. If the engine idles OK with the solenoid not hooked up, it is because someone removed the pintle from the solenoid. In that case, you DON'T need to replace it, it won't make it run any better. It did look like something was missing out of the anti dieseling solenoid when I took it out. I'll try cleaning out the needles under the caps under the bowl and maybe replacing the accelerator pump, the boot is old and cracking. Quote Link to comment
ggzilla Posted July 6, 2011 Report Share Posted July 6, 2011 Don't fix what ain't broken. The boot on my accelerator pump has been broken for years, but the pump works fine. Instead, test your accelerator pump, you will probably note it is working fine. Just look down the carb moving slowly moving the throttle. If a steady stream comes up (no trickling) then it is fine. Flat spot is usually caused by timing or by air leak. Quote Link to comment
hitch Posted July 6, 2011 Report Share Posted July 6, 2011 Yeah she wont be driving it by herself anytime soon. Only with mom or dad in the car. At this point the datsun bug has bit my wife with this car. They just went up to the car wash and they bickered and my wife won. She wants to drive it to work already. Besides, insurance for her to drive it by herself is way too expensive. Your insurance co may be much different. I'm with Farm Bureau, and because the Datsuns are considered antiques, ins is $180 every six months for my teen drivers. They both have maintained spotless driving records. Good luck, with the new driver, and the car, it looks great. Quote Link to comment
dat521gatherer Posted July 8, 2011 Author Report Share Posted July 8, 2011 Rebuilt left horn button broken tabs, cleaned contacts, fixed wire lubed sun visor shaft so the plastic mount doesnt break. It was super stiff lubed door hinges lubed seat rails fuel filter replaced ordered hatch shocks-o'rielly auto ordered wheel center caps-les schwab ordered hood hinge seals-nissanparts.cc ordered hood rod holder clip-nissanparts.cc ordered dome light-nissanparts.cc 720 rear view mirror installed. gotta love that universal ball on the back of most datsuns. unplugged wiper squirter Quote Link to comment
RadioRedline Posted July 9, 2011 Report Share Posted July 9, 2011 Love the Fastback! Radio Quote Link to comment
dat521gatherer Posted July 14, 2011 Author Report Share Posted July 14, 2011 BIG THANKS to Ericsb210 for the parts. Quote Link to comment
620green Posted August 5, 2011 Report Share Posted August 5, 2011 My wife and I bought this the other day. I'm still test driving it to see what bugs need to be worked out. We bought it so our daughter can get some driving experience but it's growing on us adults quickly. The to do list will be posted soon with lots of questions. all comments and help welcome. Let the PICS begin. Nice ride. Quote Link to comment
dat521gatherer Posted August 14, 2011 Author Report Share Posted August 14, 2011 I started to desmog it a couple weeks ago and clean up the engine bay a little. Bead blasted volt reg box and valve cove and painted them black. Before After. New battery cables and wiper washer pump with motor. egr was fitting was completely plugged egr plug at the exhaust 16x1.5 before after I found one cracked hose on the anti backfire valve to the intake and all 4 carb nuts were loose but I couldn't tighten them with everything in the way. I took out the carb jet bolts and this is what they looked like. I couldn't get the jets out cause I dont have the right lengh screw driver to get to them yet. My temporary egr block off plate just to see if it runs and it does after I figured the bolt holes need to be plugged also. Shined up one rim and bought 4 new center caps from les schwab latest pic. I want to find a thermostat housing that doesn't have the check valve or can I leave it the way I routed it to the air cleaner? Quote Link to comment
dat521gatherer Posted August 14, 2011 Author Report Share Posted August 14, 2011 I guess I'll go out and hook the hoses back up to the vacuum motor on the air cleaner. Quote Link to comment
ggzilla Posted August 26, 2011 Report Share Posted August 26, 2011 Sell that air pump on eBay for $big to someone in California! Yes you'll be glad for the heated air cleaner come winter. At 38 degrees the carb can ice over if conditions are right. It happened to my A-series several times. Quote Link to comment
