RadioRedline Posted June 29, 2011 Report Share Posted June 29, 2011 Question for Y'all! Got me a 510 (1970 4 door) Last Night. The PO lost keys. So He had taken the tumbler out of the steering column. Then he was using a small key or screwdriver to start it. It works, Did it a couple times and I got it home. I am wondering would I be able to buy from another 510 the 2 door cylinders and ignition piece with its keys, and remove and replace mine? Would this work? Thanks for your help. Radio Quote Link to comment
Wide14u Posted June 29, 2011 Report Share Posted June 29, 2011 yes that sound right to me Quote Link to comment
ggzilla Posted June 29, 2011 Report Share Posted June 29, 2011 Or just get the key code off the passenger side lock, and have a locksmith cut you a new key. Cost about $30, and it'll work like new, better than used locks. Quote Link to comment
Skib Posted June 29, 2011 Report Share Posted June 29, 2011 Or just get the key code off the passenger side lock, and have a locksmith cut you a new key. Cost about $30, and it'll work like new, better than used locks. hes missing the ignition switch Quote Link to comment
datzenmike Posted June 29, 2011 Report Share Posted June 29, 2011 Get a separate ign. with key? Quote Link to comment
ggzilla Posted June 29, 2011 Report Share Posted June 29, 2011 He said the PO had taken out the tumbler, not that he's missing it. Although usually when they take it out it goes missing... :lol: Quote Link to comment
Laecaon Posted June 29, 2011 Report Share Posted June 29, 2011 I vote for having a trunk monkey, who cares about keys. 1 Quote Link to comment
yellowdatsun Posted June 29, 2011 Report Share Posted June 29, 2011 If you're missing the tumbler, you can find another 510 one and have it re-keyed to match the door locks. Also, be aware that the early 510's had single sided ignition keys, and the later ones had double sided keys, all within 68-73. So be sure you're getting the right one for the car. Or just do like many of us and have one key for the door, and a separate one for the ignition. If you want, changing the pins inside the tumbler is easy to do yourself, but you need a few extra sets to play with to make one good one. Quote Link to comment
RadioRedline Posted July 13, 2011 Author Report Share Posted July 13, 2011 The PO threw out the tumbler RRRR! Radio Quote Link to comment
flatcat19 Posted July 13, 2011 Report Share Posted July 13, 2011 Why not go push button like what Datsun Dave sells? Quote Link to comment
RadioRedline Posted July 13, 2011 Author Report Share Posted July 13, 2011 My Goal was to save this car from the PO and OTher Destruction. I want to sell it to a person who will take proper care of it. Radio Quote Link to comment
