l13 to l16 engine swap
  • Replies 11
You have a 521? Do you mean a J13 engine?in the 520? If so, no the L16 will not fit the mounts nor will it bolt up correctly to the J13 transmission.
If you mean a 510, there were L14 engines in them in other countries. Yes the L16 should bolt in perfectly.
Guess I have a j13, which I'm finding out are a bit harder to find. Any suggestions on an easy swap. Heard about the MGB 1800 - will this work?
Thanks,
Peter
I think the first year '69? 521s still had the J13 motors in them. The Jeries and MG motors are very similar (Nissan based the J design on it) and some parts will actually swap. I don't know of anyone who has done this but it may be possible.
Just obtain a Datsun J18 out of mexico or japan and bolt it in...
MGB used the 1800, which is the Austin B-series engine. It is similar to the Datsun J-series.
  • 2 months later...
