Duncan Posted May 5, 2011 Report Share Posted May 5, 2011 I went up to No Cal a couple of weeks ago and noticed the locking gas cap off my goon was missing! Anyway, I'm looking for a replacement. DOES NOT HAVE TO BE A LOCKING CAP! A standard will do. Thanks! Link to comment
Shagy Posted May 5, 2011 Report Share Posted May 5, 2011 I have a couple if you'd like to check them out. What year is the wagon....cause believe me..it matters. Link to comment
NICOYA Posted May 6, 2011 Report Share Posted May 6, 2011 hello duncan i have this one for 69 wagon 510 Link to comment
Duncan Posted May 6, 2011 Author Report Share Posted May 6, 2011 Mine's a '71, however I have an aftermarket locking cap that says it's for a '71-later model goon, and it doesn't fit. I'm thinking the Aussie-spec goon have use the earlier filler neck, but I don't have an early one to compare it to. Eddie, you going to Torrance tomorrow night? Link to comment
NICOYA Posted May 6, 2011 Report Share Posted May 6, 2011 Mine's a '71, however I have an aftermarket locking cap that says it's for a '71-later model goon, and it doesn't fit. I'm thinking the Aussie-spec goon have use the earlier filler neck, but I don't have an early one to compare it to. Eddie, you going to Torrance tomorrow night? Sorry I don't I have to work tomorrow but I cangive you the out side diameter so you can check yours pM's your phone # and I call you or text the size Link to comment
Burabuda Posted May 6, 2011 Report Share Posted May 6, 2011 duncan what do you mean missing? Link to comment
Shagy Posted May 6, 2011 Report Share Posted May 6, 2011 Missing...I'm thinking...went and filled up, placed it on top of the pump and drove off w/out it?? Link to comment
ggzilla Posted May 6, 2011 Report Share Posted May 6, 2011 Fuel tank stuff for 510s changed several times. For JDM, these two. Not sure what the 1971 wagon used, they changed them for 1971: * 17251-22904 * 17251-21001 eBay for sale 17251-21001 For wagon USA these are the parts: to July 1969 California or April 1970 Federal These three don't interchange * 17251-22902 * 17251-22903 * 17251-22904 and * 17251-N1120/17251-N1100/17251-A5900. These are the sealed EVAPO caps. Suction relief but not vented. Link to comment
hang_510 Posted May 7, 2011 Report Share Posted May 7, 2011 can't find the number i have, but this is avail at pepboys, Stant Link to comment
RAlly_DatoB210 Posted May 7, 2011 Report Share Posted May 7, 2011 I have a generic locking one brand new cause Im to lazy to be unlocking it to get my gas out. Fits a b210 and I'll ship. Idk what they go for new but you can have it for half if it fits Link to comment
Duncan Posted May 7, 2011 Author Report Share Posted May 7, 2011 I put my goon on a trailer and went to the NoCal show a few weeks ago. I went to unload it off the trailer and the factory Nissan locking cap was missing! I was pissed! I know I locked it in, but I can only assume it came loose and fell off. I did some research and found they did factory locking gas caps on the early goon only. Due to my goon being Aussie-spec, I half suspect I may have an early filler neck on mine, and may not have all the evapo tank and hoses. I have some painted parts drying in my garage, but as soon as I can open it up, (my tools are all in there) I'm going to pull the interior side panel off and see what's happening under there. Eddie, I will pm you my number. (Or you can send me yours) I'm thinking I may have the early filler neck on mine, and that '69 cap may work. And thanks for the offers! I need to dig into my goon a bit and see what's up with that thing.. Link to comment
datrod Posted May 7, 2011 Report Share Posted May 7, 2011 I put my goon on a trailer and went to the NoCal show a few weeks ago. I went to unload it off the trailer and the factory Nissan locking cap was missing! I was pissed! I know I locked it in, but I can only assume it came loose and fell off. I did some research and found they did factory locking gas caps on the early goon only. Due to my goon being Aussie-spec, I half suspect I may have an early filler neck on mine, and may not have all the evapo tank and hoses. I have some painted parts drying in my garage, but as soon as I can open it up, (my tools are all in there) I'm going to pull the interior side panel off and see what's happening under there. Eddie, I will pm you my number. (Or you can send me yours) I'm thinking I may have the early filler neck on mine, and that '69 cap may work. And thanks for the offers! I need to dig into my goon a bit and see what's up with that thing.. Man I went thru a ton of stock gas caps at the local auto parts store and none of them fit my wagon. :( Link to comment
RAlly_DatoB210 Posted May 7, 2011 Report Share Posted May 7, 2011 i lost one on my four runner and just went to the gas station asked what they found and picked out one that fit. Link to comment
Duncan Posted May 8, 2011 Author Report Share Posted May 8, 2011 I was able to get the side panel clear enough to check out the goon gas filler, and my hunch was correct. It has the early style filler neck. Most of the other items on the car are early as well, (No DOT or EPA in Australia) so no evapo canister. That's okay because changing hoses will be much easier. Nicoya, call me bro :) John, there may be a locking cap in your immediate future :) Link to comment
Shagy Posted May 8, 2011 Report Share Posted May 8, 2011 I'm just over the hill from Nicoya if you want to look @ he ones I have. Link to comment
Duncan Posted May 9, 2011 Author Report Share Posted May 9, 2011 I'm just over the hill from Nicoya if you want to look @ he ones I have. Thanks. Apparently, mine is a '68-type filler neck. Nicoya had a '69, and it was still too big. Link to comment
ggzilla Posted May 9, 2011 Report Share Posted May 9, 2011 Early USA 510s didn't have them either. Link to comment
Shagy Posted May 9, 2011 Report Share Posted May 9, 2011 wow..I thought 68/69 were the same... you still welcome to try these if you'd like. Link to comment
