ricky Posted January 22, 2011 Author Report Share Posted January 22, 2011 thanks you guys this video has answered allot of questions Quote Link to comment
banzai510(hainz) Posted January 22, 2011 Report Share Posted January 22, 2011 thanks for preserving this. I made this as I got tired of explaining how to do head gasket/timming chains and you guys all know my spelling errors. Half the time I cant read it either but Im doing this from work. So I got to doing fast and dont proff read it. Hopefully Mklots can put the link on olddatsuns.com Quote Link to comment
ricky Posted January 22, 2011 Author Report Share Posted January 22, 2011 ok so the problem i am having is getting the timing geat back on with the chains. is there a way to do this with out removing front cover of motor? Quote Link to comment
datzenmike Posted January 22, 2011 Report Share Posted January 22, 2011 If you removed the cam sprocket without first locking the chain with a wood wedge the tensioner will fall out. The only way to get it back in is by removing the complete timing chain cover. Here's what it should look like: Here's what it will look like if the wedge isn't used: . Quote Link to comment
ricky Posted January 22, 2011 Author Report Share Posted January 22, 2011 So if the tensioner falls out it won't give enough slack to get it back on? Quote Link to comment
banzai510(hainz) Posted January 22, 2011 Report Share Posted January 22, 2011 You have to cheat it by moving the cam in direction that gives you slack. hopfully the rension is pushed in hard Quote Link to comment
ricky Posted January 22, 2011 Author Report Share Posted January 22, 2011 Screw it I'm pulling it off like in video Quote Link to comment
banzai510(hainz) Posted January 23, 2011 Report Share Posted January 23, 2011 if your going to pull the fron cover off loosen the oil pan bolt so you can pull the pan down abit. this helps from tearing the oil pan gasket. if it tears splic another on in there. also.if you do remove the front and get new stuff here you could set the pistons in the middle of the block in case your head is not aligned TDC form the machine shop. so you get the lobes in the right spot and that cam gear. if new timming set it to 1. also ck the machine shop set the lash up correctly. otherwise you might have no compression and just blow it out the exhaust and wont start. hopefully you have torq wrench. rember at end to torq tha cam and crank bolt up. Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 I do have a torq wrench. And it wad the tentiosner it came out all the way pressing chain to tight Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 Yea now that I got the cover off I am going to go a head and replace every thing. No point in using old crap if I have the chance to fix it Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 So what's the point of the little timing window? You know the little cover with 3 bolts. Quote Link to comment
Laecaon Posted January 23, 2011 Report Share Posted January 23, 2011 I decided I didnt like youtube playlists. so here is another spot for the video in full length. http://vimeo.com/19077890 Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 Can it be posted in site like cat vid and get it pind to main forums Quote Link to comment
Laecaon Posted January 23, 2011 Report Share Posted January 23, 2011 whats cat vid? vimeo might be better than all the rest... Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 Dude posted a cat eating shit on this thread Quote Link to comment
Laecaon Posted January 23, 2011 Report Share Posted January 23, 2011 I believe only youtube videos can be embedded, but you dont want an hour long video to be embedded. Im thinking of making it so people can download the video. Quote Link to comment
datzenmike Posted January 23, 2011 Report Share Posted January 23, 2011 Hainz used to sell the CD. Someone must have a copy that can be burned. Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 That would be great that video and the pics were posted made my life easy even though I feel like an amature with these datsun motors. Any one with a chevy v8 I'm that guru Quote Link to comment
Laecaon Posted January 23, 2011 Report Share Posted January 23, 2011 Im gonna upload it now, will need a certain piece of software to unwrap but everyone should have it as it is free and better than everything else imho. Link when its done. Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 Thanks Quote Link to comment
Laecaon Posted January 23, 2011 Report Share Posted January 23, 2011 http://www.mediafire.com/?79funr2nu7h2r its in 3 parts. You must have winrar installed (alot of people do) then simple double click part 1 and drag the video to where ever you want to save it too. Quote Link to comment
izzo Posted January 23, 2011 Report Share Posted January 23, 2011 LOL!!! that cat eating shit was hilarious http://player.vimeo.com/video/19077890 Quote Link to comment
izzo Posted January 23, 2011 Report Share Posted January 23, 2011 LOL!!! that cat eating shit was hilarious i cant get it to embed in here, i think its because of the code, Quote Link to comment
ricky Posted January 23, 2011 Author Report Share Posted January 23, 2011 My nephaw made me play the cat vid like 6 times Quote Link to comment
izzo Posted January 23, 2011 Report Share Posted January 23, 2011 mike put the link up on the 620 website, its on there, plus its on the vimeo site now, so should be good to go! Quote Link to comment
