doughboi916 Posted January 11, 2011 Report Share Posted January 11, 2011 im doing research on my fuel delivery for my kaDE swap.. I later plan on a built KA-T.. Looking for around 400hp? but for now i just want it on the road and i dont want to have to change the fuel pump.. will the stock tank with a in-line 255 work fine? anyone use this setup with a KA-t? also im guessing ill need a return to the tank.. how is that done? Quote Link to comment
doughboi916 Posted January 11, 2011 Author Report Share Posted January 11, 2011 researched a bit more.. I guess the engine will not get the fuel it needs is i use an inline unless i have a surge of sump?? i have no idea what they do? can some one explained? i really need hepl with this fuel stuff. im new to it.. it maybe just cheaper to go with a fuel cell? i can get on for 60 buck? will i still need a surge/sump then? Quote Link to comment
dennis Posted January 11, 2011 Report Share Posted January 11, 2011 researched a bit more.. I guess the engine will not get the fuel it needs is i use an inline unless i have a surge of sump?? i have no idea what they do? can some one explained? i really need hepl with this fuel stuff. im new to it.. it maybe just cheaper to go with a fuel cell? i can get on for 60 buck? will i still need a surge/sump then? I have a full race sump on order, this will work just fine for you application. You can also order one from Jegs or Summit Racing for a smaller price. I think it is Competition Engineering that makes them. I wanted the Full Race version because I just wanted the single outlet and not the dual outlet. I know you can easily cap off one of the outlets but thats now how I roll:rolleyes: http://www.full-race.com/catalog/product_info.php?cPath=1407_584&products_id=883 Quote Link to comment
dennis Posted January 11, 2011 Report Share Posted January 11, 2011 A surge tank is going to cost you a bit more money because you have to run a small fuel tank powered by a fuel pump and then another fuel pump to the fuel rail. I want everything as compact as possible so that is why I am running a sump. The easiest way is to run a 300ZX in tank pump. Quote Link to comment
Skib Posted January 12, 2011 Report Share Posted January 12, 2011 also im guessing ill need a return to the tank.. how is that done? :mellow: Quote Link to comment
dennis Posted January 12, 2011 Report Share Posted January 12, 2011 :mellow: I know, scary Yes, you will have to run a line back to the tank. If you run a surge tank you would have to run two lines back to your tank. Please make sure you read up on this, there are tons of posts available on this forum and many others. I dont want you setting yourself or your car on fire. Quote Link to comment
DISLEXICDIME Posted January 12, 2011 Report Share Posted January 12, 2011 I also run a 300zx intank baffl with a intank wallbro Quote Link to comment
doughboi916 Posted January 12, 2011 Author Report Share Posted January 12, 2011 thanks folk.. Quote Link to comment
doughboi916 Posted March 22, 2011 Author Report Share Posted March 22, 2011 ok i saved up... i plan on ordering all my stuff soon.. i need to know what size braided fuel line to use? im going with an external fuel pump and sump...... also will it be ok to use the stock fuel line as the return to save some money??? Quote Link to comment
Hoosier77 Posted March 22, 2011 Report Share Posted March 22, 2011 doing my sr20 swap i was going to run an inline walbro 255 to my fuel rail, do i need a sump? why cant i simply feed the high pressure fuel to the rail and route the excess back down to my tank via the return line on the rail? Quote Link to comment
doughboi916 Posted March 22, 2011 Author Report Share Posted March 22, 2011 same thing i was thinking but i guess under hard acceleration or hard turns the pump will starve for fuel?? Quote Link to comment
jesusno2 Posted March 22, 2011 Report Share Posted March 22, 2011 same thing i was thinking but i guess under hard acceleration or hard turns the pump will starve for fuel?? Bullshit, maybe on a 100% track car or a super empty tank of fuel. I'm not running a sump in the tank of my car works great, most fuel cells don't have sumps either they just use foam to keep fuel from sloshing. Stock 510 tanks draw from a tube that runs from the top to the bottom of the tank. Quote Link to comment
sssr20det510 Posted March 22, 2011 Report Share Posted March 22, 2011 You will need to enlarge the factory feed on the tank or you will run out of fuel if you are running it though all the gears, mine runs out of fuel at the top of third so i need to enlarge my feed. stock feed is to small Quote Link to comment
Wicked Saint Posted March 23, 2011 Report Share Posted March 23, 2011 From what I gathered when researching my SR swap I found that some people found with a 1/2 tank or less on long turns such as freeway on-ramps and the such you could starve for fuel. I think I went overboard but I'm using 3/8" fuel line. You can use the fuel injection rated hose and don't need braided. I had 2 AN fittings welded on to my stock tank a -6 for the supply to the surge tank and a -8 for the return from the surge tank. Here is a pic if it helps. I have been running this setup for 11 months and works great. I also have -6 fittings welded on for the reg and return. Quote Link to comment
doughboi916 Posted March 23, 2011 Author Report Share Posted March 23, 2011 i dont know dudes... Everyone's telling me different stuff.. sooo.... Im going with my original plan.... i found a sump with 2 inlet/outlets..... ones 1/2 the others 3/8..... will it be possible to use the 1/2 for sending fuel and the 3/8 for the return? this is what im looking at.. http://cgi.ebay.com/ebaymotors/Fuel-Tank-Sump-1-2-in-3-8-in-NPT-_W0QQcmdZViewItemQQhashZitem5643266d89QQitemZ370493779337QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Quote Link to comment
Jesse C. Posted March 23, 2011 Report Share Posted March 23, 2011 The return has to be slightly higher than the feed outlet. I am going to run an RCI aluminum cel with a sump. The outlets are 8AN, which is roughly 1/2 inch, to the filter and pump, then I am running 6AN , roughly 3/8", to the engine with a 3/8" return line. Running a Walbro 255 pump. Quote Link to comment
doughboi916 Posted March 23, 2011 Author Report Share Posted March 23, 2011 If the return has to be slightly higher than the feed outlet isnt 1/2 bigger then 3/8's? Quote Link to comment
Jesse C. Posted March 23, 2011 Report Share Posted March 23, 2011 If the return has to be slightly higher than the feed outlet isnt 1/2 bigger then 3/8's? Yes, 1/2 is bigger than 3/8th Quote Link to comment
doughboi916 Posted March 23, 2011 Author Report Share Posted March 23, 2011 sorry read that wrong... ^^^^^^:blink: so ill be good with 1/2 send line with a inline 255 on the stock motor.. i plan on boosting as soon as i get the car running rite on the road... also im thinking about feeding the return in the filler neck tube??? Quote Link to comment
Jesse C. Posted March 23, 2011 Report Share Posted March 23, 2011 Actually, 3/8th is fine as a feed line. I am just supplying the pump with the 8AN line and then it will be 6AN to and from the engine. Yes, you can feed the fuel back to the fill tube. Quote Link to comment
