Stubborn Gaskets
ariascarlos1990
  • Replies 12
My goon had the bumpers powder coated by the PO. I did a Google search on removing powder coating, and a lot of folks are recommending using Permatex gasket remover that is in a spray can.
If that stuff removes powder coating, I can imagine what it would do to a stubborn gasket. :cool:
I also understand it comes in a brush-on can, too.
I have not tried it, but figured it was worth mentioning.
Wire wheel on angle grinder. Naturally don't go overboard. Use a brass wire wheel it's softer. For a few bucks you can get a assorted pack of wire brushes that look like toothbrushes.
I've used the spray Permatex gasket remover with good results. You have to wait and let it work, so if in a hurry.... and it's a bit messy like paint stripper.
Paint scrapers are good too for removing most if not all gaskets. They have a good handle and grip so you can 'lean on it' and come in different widths.
bristle discs work good, but normally i use the 2 inch scothbrite roloc pads on the end of an angled die grinder, make sure you get med to fine and not the coarse grit discs, they are about a buck a peice and one should be plenty to do your front cover. turn your reg down so you cant get out of control!
