willey878 Posted January 18, 2008 Report Share Posted January 18, 2008 i just bought a 71 521 pick up and when i was driving it home i tryed to put it into second and snaped a lower part on the shifter iv looked in all my local junk yards but the dont have any 521s i was woundering if id be able to get the part off any other modles and if so witch ones thanks for all the help so far guys Quote Link to comment
]2eDeYe Posted January 18, 2008 Report Share Posted January 18, 2008 Not sure what the answer is (I'm a 620 guy) but that is a lame break... Quote Link to comment
Pacific coast Datsun Posted January 18, 2008 Report Share Posted January 18, 2008 If you can get the broken piece out maybe it can be welded back together. What sux is that the 521 shifters are specific to that truck. I may have one in my parts stash you can have...ill look. Quote Link to comment
datsunaholic Posted January 18, 2008 Report Share Posted January 18, 2008 The part that broke isn't specific to the 521... same part was used on a stock '68-73 510 and 610s- it's common to the F4W63 transmission. Quote Link to comment
Pacific coast Datsun Posted January 18, 2008 Report Share Posted January 18, 2008 TY Doug...:D I stand corrected. Quote Link to comment
willey878 Posted January 19, 2008 Author Report Share Posted January 19, 2008 If you can get the broken piece out maybe it can be welded back together. What sux is that the 521 shifters are specific to that truck. I may have one in my parts stash you can have...ill look. ok sweet il check out the junk yard again cause i know thers afew 610s ther that i might be able to get the peice from if i cant ill definly pm u to get yours off u Quote Link to comment
pope_face Posted January 19, 2008 Report Share Posted January 19, 2008 Which engine do you have? If it's the L-16 you should be able to swap the shifter bits over from the 510, but if it's the J-13 then you're pretty much stuck as they had a different transmission. I'm not sure what year the J-13 was made until, so yours is probably the L-Series, but you might want to check to be sure. Quote Link to comment
datsunaholic Posted January 19, 2008 Report Share Posted January 19, 2008 Actually the J13 one would work too, because the '69 521 used the same transmission with the different bell pattern. Possibly even the '68. Quote Link to comment
willey878 Posted January 19, 2008 Author Report Share Posted January 19, 2008 ya i have no idea what motors in it Quote Link to comment
pope_face Posted January 21, 2008 Report Share Posted January 21, 2008 Holic, I didn't know that they used the same transmission... I always thought the two were different. Willey... if you look on the side of the block you'll be able to figure it out... I think there's a number stamped on the passenger's side of the head, right under the head and close to the firewall. It should have "16" or "L16" stamped on it. Quote Link to comment
willey878 Posted February 11, 2008 Author Report Share Posted February 11, 2008 ya it is a l16 i braved the cold today and took a look my other problem is that i cant find a single 521 for miles to get parts from Quote Link to comment
kiznook Posted February 11, 2008 Report Share Posted February 11, 2008 should be a L16....right? Quote Link to comment
willey878 Posted February 12, 2008 Author Report Share Posted February 12, 2008 it is a l16 i checked Quote Link to comment
