shifter parts
willey878
i just bought a 71 521 pick up and when i was driving it home i tryed to put it into second and snaped a lower part on the shifter iv looked in all my local junk yards but the dont have any 521s i was woundering if id be able to get the part off any other modles and if so witch ones
thanks for all the help so far guys
  • Replies 12
If you can get the broken piece out maybe it can be welded back together. What sux is that the 521 shifters are specific to that truck. I may have one in my parts stash you can have...ill look.
ok sweet il check out the junk yard again cause i know thers afew 610s ther that i might be able to get the peice from if i cant ill definly pm u to get yours off u
Which engine do you have? If it's the L-16 you should be able to swap the shifter bits over from the 510, but if it's the J-13 then you're pretty much stuck as they had a different transmission. I'm not sure what year the J-13 was made until, so yours is probably the L-Series, but you might want to check to be sure.
Holic, I didn't know that they used the same transmission... I always thought the two were different.
Willey... if you look on the side of the block you'll be able to figure it out... I think there's a number stamped on the passenger's side of the head, right under the head and close to the firewall. It should have "16" or "L16" stamped on it.
  • 3 weeks later...
