72nismo Posted November 8, 2010 Report Share Posted November 8, 2010 74 Datsun 610 RHD SSS Parts Needed ASAP!!!!!!!!!! 1.fuel injected L18 COLD START VALVE on the FI system is a mechanical air bleed system and is not functioning. Anyone know were I can find one? 2. Anyone know were I can get this same battery?? email with info raiderdawglb@gmail.com THANKS!! Link to comment
Laecaon Posted November 8, 2010 Report Share Posted November 8, 2010 What is WTD? Want to... Cant find it on the netz. Link to comment
Duncan Posted November 8, 2010 Report Share Posted November 8, 2010 Sears sells the same small battery as I have one in my RHD Sunny. They have different terminals, and I had to change the battery cables :( Link to comment
kmc63 Posted November 8, 2010 Report Share Posted November 8, 2010 What is WTD? Want to... Cant find it on the netz. Ditto Link to comment
Braden Posted November 8, 2010 Report Share Posted November 8, 2010 battery should be available through chevrolet. that is if you just want the ac declo. the part number may have changed. go to a battery store and have them cross the number. also you could get a battery the same size with more output. this would also be a good question for someone at a battery store. Link to comment
72nismo Posted November 8, 2010 Author Report Share Posted November 8, 2010 WTD : means "Wanted". How old are u guys? Lol!! Link to comment
DISLEXICDIME Posted November 8, 2010 Report Share Posted November 8, 2010 i am use to seeing wtb Link to comment
Laecaon Posted November 8, 2010 Report Share Posted November 8, 2010 WTB= want to buy WTT= want to trade WTS= want to sell Link to comment
nismo dr Posted November 8, 2010 Report Share Posted November 8, 2010 wtd= what to do? Link to comment
Laecaon Posted November 8, 2010 Report Share Posted November 8, 2010 wtd: what to do? definitely the battery! more electrifying! Link to comment
kmc63 Posted November 8, 2010 Report Share Posted November 8, 2010 WTB= want to buy WTT= want to trade WTS= want to sell WTD=want to drag Link to comment
72nismo Posted November 9, 2010 Author Report Share Posted November 9, 2010 OK Fellas got me a battery. Any one know were to get or know the part number or any information regarding part???????? "fuel injected L18 COLD START VALVE on the FI system is a mechanical air bleed system and is not functioning" Thanks in advance!! Link to comment
datzenmike Posted November 9, 2010 Report Share Posted November 9, 2010 This is a JDM motor so there isn't likely any here even in a Nissan dealer. Later Z20E motors in the S110 had the equivalent. It was called an Air Regulator. It's job was to by pass the throttle valve to control the quantity of air required for increasing the idle speed when starting the motor with an under hood temperature below 80 C or 176F. Inside is a bi-metallic coil that is heated electrically when the ignition is on. As it warms, it closes the air bleed. It stays closed until the motor stops or the under hood temp drops below 80C. If I remember it has a wire to the ignition on one side and the other to the ECU and two hoses, one to before the throttle valve and one behind. Sound like yours? Or is yours heated by water? . Link to comment
datsunaholic Posted November 9, 2010 Report Share Posted November 9, 2010 Judging by the fact that he has a RHD 610 and the battery is covered in Asian characters, I doubt he's in North America. But, I doubt ANYONE has that cold-start valve. Only place that might have it is a dealer in the market that car/engine came from. But probably NLA for a decade plus. Time to improvise. Link to comment
72nismo Posted November 11, 2010 Author Report Share Posted November 11, 2010 My buddy just bought the car. Car is located in San Diego now. Does anyone know since I might not be able to find the valve if it can be rebuilt?? If so who / shop can do it??? Thanks! PART #6132-100 Link to comment
