max121 Posted May 17, 2013 Author Report Share Posted May 17, 2013 you should need 14mm I took the lower ball joint to Napa and they are the early 11mm lower ball joint painted the x-member, trans mount, and a-arms Quote Link to comment
max121 Posted May 17, 2013 Author Report Share Posted May 17, 2013 looking into buying carpet kit but i have ran into a problem I can only find a complete floor covering kit.... my car came with rubber floor mats and a carpeted tranny tunnel i cant find that kit do i have to make my own? Quote Link to comment
max121 Posted May 18, 2013 Author Report Share Posted May 18, 2013 picked up a set of 280zx struts thx to craigslist top is 240sx bottom is stock 510 Cut the perch of both sets and cleaned up the 280zx struts did some searching on what to use: I have the stock early 510 lower ball joint and steering arm but its the 11mm version (weaker) so i want to go with the stronger 14mm so i need the later 70+ steering arms if anyone has some laying around.. lol Quote Link to comment
max121 Posted May 22, 2013 Author Report Share Posted May 22, 2013 looking at passenger fender well i fount some rust so off came the fender kinda cleaned up but metal was very brittle this is lower part of fender only 1 tiny hole ill do a good sanding then rust converter and por15 then undercoating FINALY put a coat of Iron clad(por15) on floors Quote Link to comment
max121 Posted May 22, 2013 Author Report Share Posted May 22, 2013 what do i use for this seam looks like it was once a rubber seal Quote Link to comment
max121 Posted May 26, 2013 Author Report Share Posted May 26, 2013 Got a replacement panel for my door thx to tycot Here is what my door looks like before FINALY STARTED ON DRIVERS DOOR Had to adjust the door strike a bit and now its perfect just needs a Lil paint Quote Link to comment
max121 Posted November 18, 2013 Author Report Share Posted November 18, 2013 troy ermish rear cross member mounts came in and ordered a trans mount from eBay Quote Link to comment
max121 Posted November 18, 2013 Author Report Share Posted November 18, 2013 Picked up a set of enkei92's at pick n pull they need some tlc 1 Quote Link to comment
Spoona_Jay21 Posted November 19, 2013 Report Share Posted November 19, 2013 NOICE! beautiful Dime man! Quote Link to comment
max121 Posted November 23, 2013 Author Report Share Posted November 23, 2013 16x7 enkie 92s came off a 70s 280z measuring from the back side of the rim with straight edge to the hub/flange is 4" offset is 0? anyone ever put this size/offset on a 510 and what mods are needed I have the 280zx struts Quote Link to comment
hobbes_the_cat Posted November 23, 2013 Report Share Posted November 23, 2013 Those should fit perfect. 7" wide with 4" backspace is what I run. ZX struts will flush em out nice in the front, might have to roll the fender lips a little in the back. Quote Link to comment
hobbes_the_cat Posted November 23, 2013 Report Share Posted November 23, 2013 BTW those look like 14" not 16". I don't think you measure lip to lip, you measure where the tire bead seats. Right? Quote Link to comment
max121 Posted November 23, 2013 Author Report Share Posted November 23, 2013 Those should fit perfect. 7" wide with 4" backspace is what I run. ZX struts will flush em out nice in the front, might have to roll the fender lips a little in the back. sweet I wanted to make sure before I refurbished them BTW those look like 14" not 16". I don't think you measure lip to lip, you measure where the tire bead seats. Right? you are correct thx Quote Link to comment
jeph Posted November 24, 2013 Report Share Posted November 24, 2013 looks great! i believe my dad actually sold you the first 510 with the front clip cut off, was gunna be my project a long time ago. Quote Link to comment
max121 Posted November 24, 2013 Author Report Share Posted November 24, 2013 looks great! i believe my dad actually sold you the first 510 with the front clip cut off, was gunna be my project a long time ago. yea I miss that car it was red and I love a red 510 but I couldn't pass this one up did he ever get the other 2dr going? it was in rough shape rust wise but all there Quote Link to comment
jeph Posted December 27, 2013 Report Share Posted December 27, 2013 yea I miss that car it was red and I love a red 510 but I couldn't pass this one up did he ever get the other 2dr going? it was in rough shape rust wise but all there he actually gave that to me for my birthday couple years back and i been working on it slowly, i have a build thread on here for it, just been saving up and taking it slow lol Quote Link to comment
max121 Posted January 23, 2014 Author Report Share Posted January 23, 2014 checked out a couple places to get my rims fixed got a quote for 160 a rim but i found a place in Edmonds WA called Factory tire direct that did it for 50 bucks a rim they did it in one day this is before and after Turned out great!! ordering some tires tomorrow Hancook r-s3's 1 Quote Link to comment
max121 Posted February 1, 2014 Author Report Share Posted February 1, 2014 new wheels mounted .3 2 Quote Link to comment
max121 Posted February 7, 2014 Author Report Share Posted February 7, 2014 Got a donor gas tank and fuel pump out of a 85 300zx to swap into my stock 510 tank what do i use for the fuel level sensor when swaping this into my stock tank? do i just use the stock tank level sensor? Quote Link to comment
ggzilla Posted February 8, 2014 Report Share Posted February 8, 2014 For a 1985 gas tank out of a 300ZX, use a 300ZX sender unit. Quote Link to comment
max121 Posted February 8, 2014 Author Report Share Posted February 8, 2014 For a 1985 gas tank out of a 300ZX, use a 300ZX sender unit. i am cutting the top out of this one to weld into my stock datsun 510 gas tank sry i didnt specify that i guess i could just use this tank instead Quote Link to comment
max121 Posted February 18, 2014 Author Report Share Posted February 18, 2014 Do i have to have my gas tank Tig welded? or can i just use my mig i would overlap the 300zx fuel pump flange on top of the 510 tank i wish i was at my old job i could use the tig there but i dont have access to one and ive been quoted 225 to have it welded by someone that makes the tanks to sell on ebay ive spent 125 for the tank and pump already Quote Link to comment
Jester Posted February 18, 2014 Report Share Posted February 18, 2014 You don't HAVE to, it would just look better. Just make sure you get a good seal and FILL IT WITH WATER before you start. The more you can get in the better. When your done, turn it upside down for about an hour to check for leaks. Quote Link to comment
max121 Posted February 27, 2014 Author Report Share Posted February 27, 2014 Picked up a subi VLSD with 371 gear ratio cant find a place to purchase the adapters (half shafts) Ive been searching but all the links i find are no longer good i couldn't pass it up for only 100 bucks the place i got it from will be gone by the end of the week they are selling everything subi Quote Link to comment
banzai510(hainz) Posted February 27, 2014 Report Share Posted February 27, 2014 i couldn't pass it up for only 100 bucks the place i got it from will be gone by the end of the week they are selling everything subi maybe post a NUMBER SO PEOPLE CAN GET THESE. oNLY IF THEY FIT. PUTON 510REALM ALSO Quote Link to comment
