jputz Posted October 20, 2010 Report Share Posted October 20, 2010 I have been looking for replacement side windows for my 69 2door and I came across this site in one of my many searches. It says if we can supply 2 factory windows and do an order of atleast 10 sets then they will mold us replacement windows. Not sure of a price yet but if 10 of yall are interested then I will contact them. Let me know whhat yall think. Flexite Molded Windows Quote Link to comment
danfiveten Posted October 20, 2010 Report Share Posted October 20, 2010 What happens if your car gets really really hot. id like to research them more, seem like they are marketed for racers, but what about show cars, and cars in high temp areas? Do they warp? Quote Link to comment
The Octopus Posted October 20, 2010 Report Share Posted October 20, 2010 What happens if your car gets really really hot. id like to research them more, seem like they are marketed for racers, but what about show cars, and cars in high temp areas? Do they warp? Lexan parts are usually pretty heat and UV-stable. They use them in all sorts of high-heat applications. I'm in for a set. Quote Link to comment
Duke Posted October 20, 2010 Report Share Posted October 20, 2010 What happens if your car gets really really hot. id like to research them more, seem like they are marketed for racers, but what about show cars, and cars in high temp areas? Do they warp? Well, if your car got hot enough to affect polycarbonate you would have more worries than just your windows. The glass transition temperature (temp where PC starts to distort) is around 300* F. Quote Link to comment
Creepy Cruiser Posted October 21, 2010 Report Share Posted October 21, 2010 They are real easy to just make yourself, I've made many sets of them. They work pretty good, but you do have to buff them out a couple times a year to keep them really shinny (and not show scratches from washing them.). In fact 3 of the windows in my Hearse are still polycarb, and I ran it for the windshield for over 10 years, (it took that long to finally find a glass windshield). Keep in mind you can't tint it though, because as it changes temp, it out gasses moisture, and will cause it to bubble, (same with vinyl decals). All you do is get some the same thickness as your glass, lay down your pattern made from the original and trace it out, cut it out with a jigsaw or rotary cutter, sand and flame the edges, and install it just like the original was. When you're done, if it's done right, you can't tell it's not real glass. Quote Link to comment
kmc63 Posted October 21, 2010 Report Share Posted October 21, 2010 They are real easy to just make yourself, I've made many sets of them. They work pretty good, but you do have to buff them out a couple times a year to keep them really shinny (and not show scratches from washing them.). In fact 3 of the windows in my Hearse are still polycarb, and I ran it for the windshield for over 10 years, (it took that long to finally find a glass windshield). Keep in mind you can't tint it though, because as it changes temp, it out gasses moisture, and will cause it to bubble, (same with vinyl decals). All you do is get some the same thickness as your glass, lay down your pattern made from the original and trace it out, cut it out with a jigsaw or rotary cutter, sand and flame the edges, and install it just like the original was. When you're done, if it's done right, you can't tell it's not real glass. All you do is get some the same thickness as your glass, lay down your pattern made from the original and trace it out, cut it out with a jigsaw or rotary cutter, sand and flame the edges, Hey Creepy I think you meant flange the edges,right? Quote Link to comment
jputz Posted October 21, 2010 Author Report Share Posted October 21, 2010 hmmm well yall have brought up some good points thanks for the insight. Think I am gonna contact them and ask a few questions. Quote Link to comment
Creepy Cruiser Posted October 21, 2010 Report Share Posted October 21, 2010 All you do is get some the same thickness as your glass, lay down your pattern made from the original and trace it out, cut it out with a jigsaw or rotary cutter, sand and flame the edges, Hey Creepy I think you meant flange the edges,right? Nope, I meant flame, lol. When you cut polycarb (or acrylic etc...), you end up with a slight rough edge. So to fix that, you start by sanding the edge smooth (working you're way up to 800 grit or so), but it still won't be glossy like the edge of actual glass. So when you're all done sanding, take a propane torch and lightly run the flame along the edge, and this will smooth it the rest of the way and make it really shinny again (like real glass). Quote Link to comment
jputz Posted October 21, 2010 Author Report Share Posted October 21, 2010 ok well if I wanted to do this myself what would I expect to pay for a sheet of lexan, and what would be a good thickness to use? Both my side rear wiindows are busted I dont know what the proper thicknness would be. Quote Link to comment
Creepy Cruiser Posted October 22, 2010 Report Share Posted October 22, 2010 Same thickness as the front door glass. As for pricing, every place if different, so just start calling around. (btw, Lexan is a band name by GE, polycarbonate is the actual product name) You can even get it at some home centers like Home Depot and such. It might be easier to just post a wanted add on here though, and just see if anyone somewhat close to you has some rear windows for you to buy. Quote Link to comment
hang_510 Posted October 22, 2010 Report Share Posted October 22, 2010 whats the best way to reattach it to the frame? acrylic is avail in many colors Quote Link to comment
jputz Posted October 22, 2010 Author Report Share Posted October 22, 2010 Thanks for the info Creepy. Just a little iffy on shipping glass like that. Gonna check out home depot and lowes and start making phone calls. Also I am with Hang_510 what would be the best way to attach it to the window frame? Quote Link to comment
Creepy Cruiser Posted October 22, 2010 Report Share Posted October 22, 2010 I would just clean all the old broken class out of the factory rubber, and install it just like the factory glass. Quote Link to comment
