random junk and thingymajigs
all prices include shippng charges, shipping still applies to free stuff, if i forget to price somthing just ask. most of this is crap i threw in a box because its super hard to throw datsun stuff away, hopefully there is something here one of you can use.
exhaust and carb heat shields free,
71 240z seat belts 35 shipped need cleaned but are in good shape,
620 fan 15$,
620 radiator shroud 15$,
pile of smog stuff(diaphram, canister, canister bracket, other random egr crap) free,
620 air cleaner with almost new filter 30$,
single points dizzy complete and super low miles zero shaft play 28$,
620 aluminum sill plate one hole not bent or dinged up 15$,
620 ash tray chip on back but not cracked (my brother stepped on it! :angry: ) 10$,
stock 620 u bolts with lock washers and nuts 7$,
620 clutch forks used but not worn out 10$ a peice,
oil pan thingys free (unless you cant tell me what they are for),
z car tranny mount free,
bcdd solenoid for hitachi carb (extra clean and great working order) 12$,
stock radiator cap (could use blasting but will hold pressure fine 5$,
auto tranny flexplate spacers extra clean barely used no rust 15$,
coils? free but i dont know what shipping would be,
throwout bearing collar 6$,
bump stops 20$,
speedo cable came off auto tranny i dont know if it works but it has barley been used sat for 20 years 10$,
egr timer works 10$,
620 fuel filter holder with filter 7$,
new condensor 4$,
510 (? maybe 610?) engine block motor mount brackets 25$,
620 battery bracket (bent and rusty but useable 6$,
voltage regulator works fine 10$,
datsun mudflap no rips or cuts 8$ and the mud is free,
anything else like fuel hardlines or the heater hose or anything else random is free + shipping.
i hate to charge you gusy anything for this crap if i didnt have to ship it you could come and get it.
  • Replies 11
i took the bearing off of it, it sounded gritty when i took it apart so i threw out the bearing and kept the collar, you can still buy just the bearing and put on it though. most of your clutch kits come with the bearing and collar already.
Mine didn't come with either, oh well ill see what i can come up with.
  • 2 months later...
You still got the dizzy?
Braden, the original poster is no longer with us. Check his profile, maybe he has an e mail.
whats the condensors purpose? i think my truck is supposed to have one but its not there
On a points distributor the condenser or capacitor reduces arcing when they open. Less arcing and the points last longer.
