Valve Cover Vent
atkinson40
  • Replies 6
It's an INLET vent. But at idle there's not enough circulation nor vacuum on the PCV to pull. I've had a couple cars (both NAPS-Z) that did draw air in at idle. If it's blowing oil out the top vent you have problems, I've seen some L-series that did but have never actually had that issue on any of mine. A little pressure at idle is OK, a lot is usually blowby from worn rings.
It depends on the engine, year and model. Some datsun engines it is inlet, others it is outlet.
Venting with a hose is OK, but connecting it to the PCV valve is better, as it will ventilate the block. Lower oil consumption and lower pressure loss. Side benefit of lower emissions too.
Yes, if your rings are worn, too much blowby will get past the pistons and pressurize the block. This can cause the PCV valve to gunk up or overload, so some guys disconnect it and just use a vent hose. Better is to repair the engine.
