sdsurf Posted August 18, 2010 Report Share Posted August 18, 2010 I keep blowing my exhaust flange gasket. STock L-16 manifold into stock exhaust. I thought about doubling it up with 2. Any thoughts? Quote Link to comment
MikeRL411 Posted August 18, 2010 Report Share Posted August 18, 2010 Auto parts stores sell a silicate based "muffler sealant" in a tube. It is high temperature resistant. Put a circle around the 2 exhaust holes in the gasket, on both sides, and install. Hopefully this willfill in any warping of the flanges and seal the joint. I used this method to fabricate an exhaust gasket for my RL411 out of 2 510 gaskets. It's been holding for 12 years. Quote Link to comment
Pacific coast Datsun Posted August 18, 2010 Report Share Posted August 18, 2010 I used to run 2 gaskets on my Mazda truck because 1 of the flanges was slightly warped. Worked fine :D Maybe do 2 & use the sealant to be sure. Quote Link to comment
I'm BLUE Posted August 18, 2010 Report Share Posted August 18, 2010 ^^^ I was just about to say you should check for warpage on the exhaust manifold surface , as well as cylinder head surface :D Quote Link to comment
Braden Posted August 18, 2010 Report Share Posted August 18, 2010 i doubt the manifold side would be warped enough to make it leak but the flange side would be, i made a flange out of 1/4 inch plate and its been working great! just use the gasket as a template ! Quote Link to comment
motavated Posted August 18, 2010 Report Share Posted August 18, 2010 It could be that the flange could be hitting the trans. Causing a bad seal. Causing it to malfunction down to road.... Quote Link to comment
I'm BLUE Posted August 18, 2010 Report Share Posted August 18, 2010 i doubt the manifold side would be warped enough to make it leak but the flange side would be, i made a flange out of 1/4 inch plate and its been working great! just use the gasket as a template ! Wellllllllllllllllll ,,, you have to work on enough over-heated motors to see this :lol: Quote Link to comment
