IGN light - 521
sdsurf
  • Replies 12
The IGN light is nothing more than the alternator light. When it's on, the alternator or regulator is bad, or the incorrect alternator is installed (IR with the ext reg still hooked up, etc)
Below is the alternator in the truck (external or internal?).
These are the two spares I have. Which is correct?
Thanks
ok so the belt is tight. I swapped out the alternator I had for another spare and did the cheater alternator test. Pull the negative on the battery and see if it keeps running, it did (with the old alt it shut off). so the light is still on. Thoughts?
ck every now and then to make sure battery dont OOZ out acid. Sign of cooking the battery. cl water level.
I have been noticing my battery oozing water/electrolyte. So does this mean my regulator is shot and also the reason my IGN light is on?
