wayno Posted June 2, 2011 Report Share Posted June 2, 2011 Just bought a low mileage sd22 with 5 speed in a rolling chassis... Thinking of putting it in my 521... Would you do this swap again or? I did it, this is a 1969 datsun 521(I made it a kingcab) truck cab sitting on a 1981-82 datsun 720 KC diesel frame with a SD25 diesel engine, it is the same block as a SD22 engine, this truck has power steering, power brakes, it also has the 1984 nissan shortshaft 5 speed transmission, so the shifter comes out the stock 521 shifter hole. I used the 720 diesel wiring harness with the 720 tilt steering column, so I have intermitant wipers, lights and key are on the column. I think this link below will get you to my project, I am just recently making this truck a daily driver, you know how it is, you get the bulk of the project done then start dragging the feet when other projects get in the way. wayno http://community.ratsun.net/topic/22928-1969-datsun-kingcab-project/page__view__findpost__p__375219__hl__wayno__fromsearch__1 1 Quote Link to comment
Cahoon520 Posted June 2, 2011 Author Report Share Posted June 2, 2011 Heres some shitty cell phone pics. 1 Quote Link to comment
wayno Posted June 2, 2011 Report Share Posted June 2, 2011 Does your windshield have a few issues?:blink: Everyone needs a arm rest for the right elbow. :cool: 1 Quote Link to comment
Cahoon520 Posted June 2, 2011 Author Report Share Posted June 2, 2011 Does your windshield have a few issues?:blink: Everyone needs a arm rest for the right elbow. :cool: Ya i found a new windshield at a local glass shop but need new gasket(ebay). I didn't have room for the sub woofer any where else but it does make a good arm rest. 1 Quote Link to comment
Cahoon520 Posted August 7, 2011 Author Report Share Posted August 7, 2011 It is finally drivable! I have spent the last two days driving this truck with zero I issues. A big Thank You to all the folks on Ratsun for all your help in getting this truck back on the road. This truck is far from done but at least I can drive it. My next project on this truck is a ball joint disk brake conversion, and raising it up a bit in the front. Heres a few updated pics from yesterday. 1 Quote Link to comment
wayno Posted August 8, 2011 Report Share Posted August 8, 2011 When you get the frontend done/completed and take it in to have it aligned, they will ajust the height for alingment purposes. But if it is hitting the fenders or bottoming out you can get under there and tighten the torsion bars the same amount on both sides. I to have taken a long time to get mine to DD status also, but it feels good to be there, doesn't it. 1 Quote Link to comment
Master-O-Turbonics Posted October 4, 2011 Report Share Posted October 4, 2011 Any updates on your truck? How's it driving? 1 Quote Link to comment
Cahoon520 Posted October 4, 2011 Author Report Share Posted October 4, 2011 Its running great I have been using it as daily driver for a month now with no problems at all except it needing a new altenator last weekend. 1 Quote Link to comment
Master-O-Turbonics Posted October 4, 2011 Report Share Posted October 4, 2011 Eek I know those SD22 alternators aren't cheap! Awesome to see another guy with an old diesel datsun! Mine is only in the building stage but is moving along quickly! What kind of fuel mileage are you seeing? 1 Quote Link to comment
Cahoon520 Posted October 4, 2011 Author Report Share Posted October 4, 2011 I just put a gasser alternator because I didnt need the vacuum pump because I dont have power brakes. Iam getting about 35 40 mpg. Cant wait to see more of your 521 diesel conversion. 1 Quote Link to comment
wayno Posted October 4, 2011 Report Share Posted October 4, 2011 I just put a gasser alternator because I didnt need the vacuum pump because I dont have power brakes. Iam getting about 35 40 mpg. Cant wait to see more of your 521 diesel conversion. What, no photos of the alt. conversion. :lol: What are you doing with the power brake pump, someone needed one of them recently. 1 Quote Link to comment
Cahoon520 Posted October 4, 2011 Author Report Share Posted October 4, 2011 It wasnt much too do just basicly take oyt bolt back in again the only thing that I had to do different is get a plug from a gasser 720 and solder it onto the the diesle harness. My vacuum pump was broken. 1 Quote Link to comment
wayno Posted October 5, 2011 Report Share Posted October 5, 2011 I just put a gasser alternator because I didnt need the vacuum pump because I dont have power brakes. Iam getting about 35 40 mpg. Cant wait to see more of your 521 diesel conversion. I have only once got mileage like what you are talking about here, I got 36mpg once on the hiway. Your not talking about kilometers, correct? I have a SD25 in my 521 now, but have never taken it on a long trip yet to find out the mileage yet. My speedo is off also, it shows 80mph when I am doing 70mph, I need to change the rear gears to fix it. 1 Quote Link to comment
Cahoon520 Posted October 5, 2011 Author Report Share Posted October 5, 2011 Iam getting 6l/100km (thats the canadian way) when I convert that from metric I get about 39 mpg. I drive mosty highway to work. My speedo is also out 70 mph is about 65 mph on my gps. My 520 probably weighs a little less than your king cab 521. 1 Quote Link to comment
wayno Posted October 5, 2011 Report Share Posted October 5, 2011 Iam getting 6l/100km (thats the canadian way) when I convert that from metric I get about 39 mpg. I drive mosty highway to work. My speedo is also out 70 mph is about 65 mph on my gps. My 520 probably weighs a little less than your king cab 521. I did forget to mention that the 36mpg that I did get was in my 1982 datsun 720 diesel(SD22) truck with the tailgate down going 55 to 60mph empty. I am unable to drive that slow, I showed great restraint that day, it was everything I could do to keep my foot out of the pedal, on the way back I got about 30mpg going 65+ with an engine in the back and the tailgate up. 1 Quote Link to comment
Cahoon520 Posted October 5, 2011 Author Report Share Posted October 5, 2011 I did forget to mention that the 36mpg that I did get was in my 1982 datsun 720 diesel(SD22) truck with the tailgate down going 55 to 60mph empty. I am unable to drive that slow, I showed great restraint that day, it was everything I could do to keep my foot out of the pedal, on the way back I got about 30mpg going 65+ with an engine in the back and the tailgate up. Heres an interesting artical I found about having the tailgate up or down... http://www.trucktestdigest.com/TTDfeatures/FeatureTailgateUporDown.htm The speed limit around here is 100 kmh or 62 mph so keeping it under 65 is not a problem. 1 Quote Link to comment
wayno Posted October 5, 2011 Report Share Posted October 5, 2011 So you can't let me be happy in my ignorance.:lol: :lol: :lol: 1 Quote Link to comment
Cahoon520 Posted October 5, 2011 Author Report Share Posted October 5, 2011 So you can't let me be happy in my ignorance.:lol: :lol: :lol: Sorry,Wayno Im just a jerk that way. :lol: 1 Quote Link to comment
Cahoon520 Posted February 5, 2012 Author Report Share Posted February 5, 2012 This weekend I added power lock actuators and a door pop solenoid. The door pod solenoid that that I had was a 15 pound and it was not big enough to open the doors, so I am going to order a bigger one. so here is a few pics of the installation. The actuators just bolted to the the out side door handles it was a very easy job. Here is a picture of the new gauges that got from Radio that I converted to LEDs. 1 Quote Link to comment
RadioRedline Posted February 5, 2012 Report Share Posted February 5, 2012 As always, quality workmanship! Radio 1 Quote Link to comment
Z chopper Posted February 6, 2012 Report Share Posted February 6, 2012 the led lighting on the guages looks very nice 1 Quote Link to comment
Cahoon520 Posted February 7, 2012 Author Report Share Posted February 7, 2012 Snow pic. 1 Quote Link to comment
Cahoon520 Posted April 30, 2012 Author Report Share Posted April 30, 2012 So I started on my stereo stuff here are my kick pods 1 Quote Link to comment
Master-O-Turbonics Posted May 5, 2012 Report Share Posted May 5, 2012 Nice! I am hoping for 25mpg with my setup. 33" tires aren't going to make for great MPG I don't think. A coworker and I have been building a setup to filter used ATF to 5 microns and have been running his 96' 7.3 powerstroke on 90% ATF, 10% pump diesel. Soon to be building my own filtering setup. Screw $4 a gallon for diesel! LOL! Oh, Got my SD22 running! 1 Quote Link to comment
RadioRedline Posted May 22, 2012 Report Share Posted May 22, 2012 Uh...Android eh... Oh well. :sleep: *Goes and orders Apple Logo taking a shit on that stupid robot Decal* HOPE IT EXISTS!!! :devil: Radio 1 Quote Link to comment
