chebetio510 Posted May 18, 2010 Report Share Posted May 18, 2010 So coming home today on the 5 freeway.. i felt the car strted to lock up.. and slaming noise when shifting gears or accelerating hard... about 5 miles from home hear the big bang.. My diff is gone lol... it was a subaru 3.90 open.. so now neede to go diff hunting.. Quote Link to comment
I'm BLUE Posted May 18, 2010 Report Share Posted May 18, 2010 So coming home today on the 5 freeway.. i felt the car strted to lock up.. and slaming noise when shifting gears or accelerating hard... about 5 miles from home hear the big bang.. My diff is gone lol... it was a subaru 3.90 open.. so now neede to go diff hunting.. That sucks man ! well at least you know where to look. I have to put in the OPEN R-200 I got from Phlebmaster into my 1973 Datsun 240z here pretty soon ( current is a worn R-180 )( when I get monies available to buy the rubber mount first because one that is in there is beaten to death ! LOL ) You can really start to hear the whine on the drive side of the Ring in the differential just whine and howl :blink: :lol: :unsure: At Least I have my U-Joint Half-Shafts Rebuilt ready to go in with the new differential mount and the R-200 Diff when I get the monies for the rubber :cool: Good luck Man. Quote Link to comment
chebetio510 Posted May 18, 2010 Author Report Share Posted May 18, 2010 does the mustache bar have to be modded on the z? Quote Link to comment
Skib Posted May 18, 2010 Report Share Posted May 18, 2010 does the mustache bar have to be modded on the z? for the R200? Quote Link to comment
I'm BLUE Posted May 18, 2010 Report Share Posted May 18, 2010 does the mustache bar have to be modded on the z? IDK what to modify on the R-180 m-bar to get the R-200 Diff to fit :huh: , but that's why I just bought the R-200 complete set-up out of a 77 280z. ( Included is the R-200 --->>> mustache bar , swing arms , cv joints , hubs , bolts , the works it's all there ready to bolt in as an entire unit :cool: ) Just bolts in , and is easy peeezy ! I also have 280zx Turbo Half-shafts with stub axles , and companion flanges , but I choose to use the U-Joint Half-Shafts from a spare 240z set I rebuilt already , why not ya know ? :lol: :D That reminds me , I need Bushings for the R-200 M-Bar before it goes in :o Quote Link to comment
chebetio510 Posted May 18, 2010 Author Report Share Posted May 18, 2010 well what im thinking if i get a open r200 for my 510 i need to modify the nustache bar right? Quote Link to comment
datzenmike Posted May 18, 2010 Report Share Posted May 18, 2010 So coming home today on the 5 freeway.. i felt the car strted to lock up.. and slaming noise when shifting gears or accelerating hard... about 5 miles from home hear the big bang.. My diff is gone lol... it was a subaru 3.90 open.. so now neede to go diff hunting.. Too many one tire fires. :lol: LSd'll fix that. Quote Link to comment
chebetio510 Posted May 18, 2010 Author Report Share Posted May 18, 2010 if i could find an lsd.. lol.. would be nice... Quote Link to comment
banzai510(hainz) Posted May 18, 2010 Report Share Posted May 18, 2010 find another R160 or R180 no mods to mustasch bar but most are the tall gear ratios and if out of a later car they have the snap in type diff and that needs to be converted to the 4 bolt flange. Quote Link to comment
RadioLobo Posted May 18, 2010 Report Share Posted May 18, 2010 Dont mean to jack your thread but ive been hearing some hard hitting noises from the rear with i shift gears. I jacked up the rear and turned the drive shaft and it moves about an inch or two before it engages the differential, is that normal? :blink: I thought it would be the u joints so i ordered some to replace all of them on my car. Quote Link to comment
datzenmike Posted May 18, 2010 Report Share Posted May 18, 2010 Replace the U joints first. This will likely fix the problem. Quote Link to comment
banzai510(hainz) Posted May 19, 2010 Report Share Posted May 19, 2010 Lobos If you joints are bad you should be able to tell. look close youll see slop whear the caps go on it will be destryoed. Quote Link to comment
RadioLobo Posted May 19, 2010 Report Share Posted May 19, 2010 the drive shaft joints seem ok, theres very hardly any movement there more in the half shafts, but think of it this way if i didn't have the drive shaft connected to the rear, the top plate to the diffy would still rotate about an inch and then start turning my tires it makes a hard hitting sound which seems similar to the one im hearing when driving. Im no mechanic so ill jack up the car again and look closer, thanks mike & hainz Quote Link to comment
banzai510(hainz) Posted May 19, 2010 Report Share Posted May 19, 2010 what I do to ck half shaft ,Is jack up the car and move the wheel while you under it. ck closely to the inner and outter U joint. move wheel back and worth. Do both side. If U joint is worn it will be obvious. Esp on a lowered 510. I have never changed a Driveline U joint in 22years of owner datsun 510s/ Half shfts I have doem many a half shaft swap. Got spares ready to go in!!!!!!! Quote Link to comment
INDY510 Posted May 19, 2010 Report Share Posted May 19, 2010 My friend broke a U-joint on his 510,,, and it snapped the flange on the diff. He had to get a new "U-shaped" flange for the diff,,, and 4 new U-joints............ and a bigger hammer..... :lol: Quote Link to comment
