Chris#51EPGraham Posted May 10, 2010 Report Share Posted May 10, 2010 Bumped and updated again on Sept 10, 2010. See list below...a large collection of '69 - '73 Datsun/Nissan PL510 stock and aftermarket parts salvaged from various 510's and other Datsuns, almost all used but also a few new items. I also have some other parts not listed. Have nothing specific to Z cars other than a B series 5 speed trans from an 810. Have never owned or stripped a wagon. News flash! I just shipped a boxed oil pan full of other parts from here (Maryland) to Corona, CA for $18.45 via USPS parcel post and it arrived in 2 days - parcel post can take up to 7 days and UPS-like tracking is available for a mere 80 cents extra. The low price tradeoff is a gamble that it might be fast or slow. USPS parcel quotes run 30 - 40% cheaper than priority or UPS. I encourage people to ask about all manner of small and trivial parts - they're dirt cheap to ship in USPS flat rate boxes, I've got so many that most aren't listed. It usually takes me a day or so to take photos if they're needed unless I already have them. I check specifications carefully. Chris at 410-286-0677....DIRECT EMAIL gets quickest response. Need to know your location. cgr8818021@bluefrog.com 3:90 '71 open diff rear... I'm now parting this out myself - stub axles sold, all other parts still available. Smaller parts = cheaper to ship! Back cover, nicely cleaned up with bolts and moustache bar plate/nuts -------$30 shipped Diff side bearings/carriers/shims ----------------------------------------------------- $30/pair, shipped Open diff itself - good core for making a welded/locked diff ----------------------$40 shipped Ring and pinion ----------------------------------------------------------------------------$40 shipped Driveshafts, stock 510 sedan, all could could use at least one ujoint----------$40 each Halfshafts --------------------------------------------------------------------------------$40 each or $60 a pair, shipped Stub axles --------------------------------------------------------------------------------$50 each, shipped Engines and engine parts: L20b '74 square port.... ran great when pulled--------------------------------------------------- SOLD L18 Short block w/ flywheel, stick, from '73 610, rebuildable core--------------------------$60 Oil pan, late style stock PL510 ---------------------------------------------------------------------- SOLD Oil pan, late style stock PL510 with brazed in oil temp guage fitting -------------------------$40 Oil pan, 1970 521 truck --------------- ---------------------------------------------------------------$40 Front covers, L16/L18 (I have none for L20b) ----------------------------------------------------$20 Valve covers, late style L16/L18/L20b) ----------------------------------------------------------- $20 Transmissions: B series 5 speed transmission from '78 810, same type as later z car trans, worked fairly well on test drive but high mileage and could use rebuild --------------$80 JATCO '73 PL510 auto trans -----------------------------------------------------------------$40 Suspenson: Quickor rear antiroll bar w/ fittings, raced for years, old and rough -----------------------$80 Homemade adjustable 1" front bar w/ no fittings, blacksmith special ----------------------$20 510 strut housings, modified for CO, bare, not shortened ------------------------------------$80 shipped 510 strut housings shortened for Rabbit/scirocco inserts, CO, cut/rewelded ------------ $60 shipped (all struts listed are wirebrushed clean and repainted) G-Machine delrin/aluminum camber adjustment bushings, 1 pair, NEW ------------- SOLD G-Machine delrin/aluminum bushings second set, USED --------------------------------$20/pair, shipped Carrera coilover sleeves ------------------------------------------------------------------------ SOLD Carrera 2.5" ID x 10" long x 275 lb/in coilover springs, chromed, a little rusty ------$90/pair, shipped Bumpsteer spacers ------------------------------------------------------------------------------SOLD Rear trailing arms, stock, from a California car, in decent condition -------------------$80 pair plus shipping Front control arms aka transverse links: One set stripped + repainted w/ reinforcing welds, late style----------------------------$60/pair, shipped Other sets in used cond, unmodified, late style---------------------------------------------$40/pair, shipped One pair '68 -'69 style in used cond for conical bushings, rare --------------------------$40/pair, shipped LCA pivot studs, late style --------------------------------------------------------------------- $40/pair, shipped Wheels: Early Corvair 13" x 5.5" OEM steel wheels: One set of 4 in very good shape, no tires mounted -----------------------------------------$20/all 4 Another set of 4, good with a few dings + maybe usable old 175/70s -------------------$20/all 4 Race tires: Hoosier 10.0" x 21.5" roadrace slicks, R45, formula car casing -------------------------$20/all 4 Hoosier A60 - 13 bias Dirt Stockers, set of 4, old, good tread, DOT---------------------$20/all 4 Oil cooler: Thermo-Cool oil cooler, durable copper tube type, 18" x 7 5/8" = tight --------------- SOLD Cooling & heating system: Stock 510 radiators, repairable leaks ---------------------------------------------------------$20 each Heater assemblies, '71 and later type ---------------------------------------------------------$40 Body and glass: Fiberglass front spoiler, Dobi style, chopped mat construction --------------------------$60 2 door quarter windows ------------------------------------------------------------------------- $40/pair 2 door doors, white, decent ---------------------------------------------------------------------$80/pair or $40 each 2 door doors, rusty, good for cut-out repair sections -------------------------------------- $40/pair or $20 each 2 door glass only ----------------------------------------------------------------------------------$20/each Sedan back window, plain, factory tinted ----------------------------------------------------$40 Sedan back window, factory tinted w/factory defrost -------------------------------------$100 4 dr/wagon right front glass, factory tinted -------------------------------------------------$20 Fender, right front only, late style, awful, for racing or city driving ---------------------$20 (other two SOLD) Hood, stock, not bad except for hideous lime green color -------------------------------- SOLD Hood, stock, corners bent from a "latch incident", otherwise decent -------------------$20 Hood, stock with inner braces removed for racing, 8 lbs lighter, decent ---------------$40 Trunk lid, good except for repairable damage at lock hole, no lock --------------------- SOLD Trunk lid, slightly distorted from ITC road race car----------------------------------------$20 Bumpers, '71 with overriders ------------------------------------------------------------------- SOLD Stickshift pedal cluster/column support ----------------------------------------------------- SOLD Set of 4 early style hub caps - decent looking with slight dents -------------------------- $35 shipped '74 610: Running light assemblies, front, both ---------------------------------------------------------$40 shipped Turn signal light assy's, front, both ------------------------------------------------------------$40 shipped Taillight assembly, left only ---------------------------------------------------------------------$30 shipped (Package deal, all 610 lights listed above -----------------$80 shipped) ---------------------------------------------------------------------------------------------------------------- Link to comment
Jesse C. Posted May 10, 2010 Report Share Posted May 10, 2010 Do you have a pic of the DOBI spoiler? Thanks! Link to comment
Chris#51EPGraham Posted May 10, 2010 Author Report Share Posted May 10, 2010 Do you have a pic of the DOBI spoiler? Thanks! Jesse, Clickable thumbnails to a medium file size. Email me for 1632 x 1232. Shipping would be a lot, but I think $50 plus whatever that is still beats the cost of new ones. This is chopped fiberglass matt construction. It came off a road racing car, and the little oblong hole in the middle was for an SCCA required tow hook. If you want a shipping quote, give me a zip code. Link to comment
hang_510 Posted May 10, 2010 Report Share Posted May 10, 2010 Shipping would be a lot, but I think $50 plus whatever that is still beats the cost of new ones. check to socal, cuz im intrested too. other big items as well... :angry: Link to comment
Chris#51EPGraham Posted May 10, 2010 Author Report Share Posted May 10, 2010 check to socal, cuz im intrested too. other big items as well... :angry: He's in So Cal too. What's your zip? Auctions aren't allowed... I guess you'll have to fight? To give you a rough idea of astronomical shipping costs to out west, I was just quoted $108 to ship a pair of trailing arms to Mesa AZ by UPS ground, including cost of boxes. That was at a UPS store, which doesn't mark up the calculator price. I just found out the hard way that Pack-N-Ship marks up UPS prices by about 20%. I'm working on numbers for this airdam. Big difference is that it only weighs about 1.25 lbs, so figuring the cardboard + packaging will outweigh it by a lot, maybe 5 lbs shipping weight. Link to comment
hang_510 Posted May 10, 2010 Report Share Posted May 10, 2010 Auctions aren't allowed... I guess you'll have to fight? That was at a UPS store, bring it out here for a tug-o-war and its on! im :cool: being on top of the wait list, its a spare for me. use 90050 (should be LA - close enough for an est.) be careful (20%!!! :o ) as ive shipped on someone elses acct from one and later found out they charged overnight and not ground!!! a cyl head(no cam) back east was only ~$60 from here Link to comment
Chris#51EPGraham Posted May 10, 2010 Author Report Share Posted May 10, 2010 bring it out here for a tug-o-war and its on! im :cool: being on top of the wait list, its a spare for me. use 90050 (should be LA - close enough for an est.) be careful (20%!!! :o ) as ive shipped on someone elses acct from one and later found out they charged overnight and not ground!!! a cyl head(no cam) back east was only ~$60 from here Lol. You're talking about Pack-n-Ship stealth-charging for overnight when you used ground? Don't worry, I'll never use them again. My experience was shipping six alloy wheels to RI and I was confused as to the difference between P-n-S and the UPS store just across the boulevard. The springtime pollen count here is so high that I'm dizzy from shortness of breath after hauling two heavy boxes into the store, so my defenses failed me as they were weighed and the price quoted. The quote directly from UPS (ground) was $54. Same UPS ground service from Pack-n-Ship was $72. I'd been quoted $54 for the same thing 5 or 6 months before, so in my confusion I thought maybe UPS rates had gone up. The difference with FedEx: apparently they're the cheapest option of all, maybe even cheaper than USPS parcel post. Problem is that they always deliver to the wrong address and sometimes lose packages for weeks. It's great comedy if your customer has friendly neighbors and a sense of humor, but otherwise dicey. Ok, UPS online shipping calculator is down for some reason. Both LA and San Diego come up with the same price on USPS priority mail: LA zip 90050 - $46.80 + $12.00 box and pack + $50 part price = $108.80 total cost shipped. San Diego zip 92110 (took a wild guess) - exactly the same prices = $108.80 total cost shipped. I can get a UPS quote locally tomorrow. It could be more or less. I'm guessing at the price of an oddball sized large box trying to overestimate, so that could be less. Link to comment
wana510 Posted May 11, 2010 Report Share Posted May 11, 2010 u wouldnt happen to have a 2dr front windshield? Link to comment
Chris#51EPGraham Posted May 11, 2010 Author Report Share Posted May 11, 2010 u wouldnt happen to have a 2dr front windshield? I'm sorry, I don't......got a lot of other 510 glass though. Link to comment
AZhitman Posted May 11, 2010 Report Share Posted May 11, 2010 Chris, GLWS. Cool that you're trying to help get these parts out to people. I spent the weekend autocrossing in PA and wishing I had your Dime there to smack around the competition... That thing is SO tempting. Best of luck with selling off your collection. Link to comment
thisisthenewsic Posted May 11, 2010 Report Share Posted May 11, 2010 Pics of rear swaybar. And price shipped to 92563. Also. Where do the camber adjustment bushing install at. Front or rear? Link to comment
DAW Posted May 11, 2010 Report Share Posted May 11, 2010 Check Greyhound Bus Lines Freight for shipping costs on items like those. DAW Link to comment
hang_510 Posted May 11, 2010 Report Share Posted May 11, 2010 Lol. You're talking about Pack-n-Ship stealth-charging for overnight when you used ground? Don't worry, I'll never use them again. (took a wild guess) - exactly the same prices = $108.80 total cost shipped. thats gonna kill it for me :angry: they pop up locally from time to time for ~$100 GL Link to comment
Chris#51EPGraham Posted May 11, 2010 Author Report Share Posted May 11, 2010 To everybody...thanks for the great avalanche of responses coming in now..I needed it! Pics of rear swaybar. And price shipped to 92563. Also. Where do the camber adjustment bushing install at. Front or rear? G-Machine camber adj. bushings: they're installed in place of the stock front control arm (transverse link) pivot bushings. They only work on late style control arms w/ cylindrical bushings. Early style arms used a conical bushing in a conical seat. Give me a few for pics of swaybar, since I didn't have any taken yet. Link to comment
kmc63 Posted May 12, 2010 Report Share Posted May 12, 2010 Looking for a windshield washer motor.Not wiper motor.pic? zip.98292 :) Link to comment
Chris#51EPGraham Posted May 12, 2010 Author Report Share Posted May 12, 2010 thats gonna kill it for me :angry: they pop up locally from time to time for ~$100 GL I understand entirely. I'm still looking for a way to get the shipping/boxing cost down but I struck out talking directly to UPS. They were even higher than USPS for an item of this size. Coming up with a box that size cheap enough is gonna require some extra ingenuity. DAW...yeah, vaguely I knew about the Greyhound option and will look into it via the station in Annapolis. Not sure I trust them with fiberglass, but probably good for antiroll bars and the like. Link to comment
Chris#51EPGraham Posted May 12, 2010 Author Report Share Posted May 12, 2010 Chris, GLWS. Cool that you're trying to help get these parts out to people. I spent the weekend autocrossing in PA and wishing I had your Dime there to smack around the competition... That thing is SO tempting. Best of luck with selling off your collection. AZ to autocrossing in PA? What did you drive/co-drive? If you come east a lot, I heartily recommend running any of the SCCA events at FedEx field in Landover MD. It's an enormous lot with hills, so the courses are fast and always interesting, also a great group of people with high energy and always 200+ entries, even now. 240 - 250 used to be average. That's where I used to run. Link to comment
Jesse C. Posted May 12, 2010 Report Share Posted May 12, 2010 Thanks for the info, but, it is not the one I seek. Link to comment
Chris#51EPGraham Posted May 12, 2010 Author Report Share Posted May 12, 2010 Thanks for the info, but, it is not the one I seek. Yeah, I know...the shipping has gotten to look prohibitive. Need anything small :o ? Link to comment
hang_510 Posted May 12, 2010 Report Share Posted May 12, 2010 Looking for a windshield washer motor.Not wiper motor.pic? zip.98292 :) the current DQ has simple replacements for it! ive also repaired some that didnt pump. often the aluminum piece to the rotor vane is rotted. AL can multi-folded works great! ;) Link to comment
Chris#51EPGraham Posted May 12, 2010 Author Report Share Posted May 12, 2010 the current DQ has simple replacements for it! ive also repaired some that didnt pump. often the aluminum piece to the rotor vane is rotted. AL can multi-folded works great! ;) Yeah, all 3 of the ones I dug up were total junk, like I wouldn't even try to repair them. Another idea is to adapt one from a Toyota because they're much higher quality. I've got a couple, but any salvage yard would have them too. Link to comment
kmc63 Posted May 13, 2010 Report Share Posted May 13, 2010 the current DQ has simple replacements for it! ive also repaired some that didnt pump. often the aluminum piece to the rotor vane is rotted. AL can multi-folded works great! ;) Thanks for the info hang510 I will check the DQ ;) Link to comment
jefe de jefes Posted May 13, 2010 Report Share Posted May 13, 2010 He's in So Cal too. What's your zip? Auctions aren't allowed... I guess you'll have to fight? To give you a rough idea of astronomical shipping costs to out west, I was just quoted $108 to ship a pair of trailing arms to Mesa AZ by UPS ground, including cost of boxes. That was at a UPS store, which doesn't mark up the calculator price. I just found out the hard way that Pack-N-Ship marks up UPS prices by about 20%. I'm working on numbers for this airdam. Big difference is that it only weighs about 1.25 lbs, so figuring the cardboard + packaging will outweigh it by a lot, maybe 5 lbs shipping weight. hey Chris. Try usps. I shipped an entire 69 dash to ratsun member nico for less than $25. That's shipped priority from Fresno county to the bay area with delivery confirmation and insurance. Package weighed 26lbs and measured 60x10x10. *edit* Nvm, your east coast. Same packaged shipped to the east coast would have cost around $60. Still worth a look. Link to comment
DREWSDIME Posted May 13, 2010 Report Share Posted May 13, 2010 How much to ship the front control arm bearings to 91786 Upland,CA ? Link to comment
Chris#51EPGraham Posted May 13, 2010 Author Report Share Posted May 13, 2010 Pics of rear swaybar. And price shipped to 92563. Also. Where do the camber adjustment bushing install at. Front or rear? Clickable thumbnails, Quickor rear AR bar: Still gotta check on shipping. Link to comment
