DISLEXICDIME Posted May 5, 2010 Report Share Posted May 5, 2010 When you swapped your 510 did you eliminate your evaperation tank in the trunk ? Quote Link to comment
Icehouse Posted May 5, 2010 Report Share Posted May 5, 2010 My 68's don't have them haha :) Quote Link to comment
DISLEXICDIME Posted May 5, 2010 Author Report Share Posted May 5, 2010 I got rid of mine but I noticed when I pull the cap off there is a lot of suction . There is so much suction te tank makes a thump nois when you pull the cap off Quote Link to comment
hang_510 Posted May 5, 2010 Report Share Posted May 5, 2010 I got rid of mine but I noticed when I pull the cap off there is a lot of suction . There is so much suction te tank makes a thump nois when you pull the cap off at least change to a vented cap. i had a tank collapse from a vacuum. :o Quote Link to comment
inline4 Posted May 6, 2010 Report Share Posted May 6, 2010 at least change to a vented cap. i had a tank collapse from a vacuum. :o black hole???? mine doesnt make a swoosh noise anymore. it just probably vents into the cabin. Quote Link to comment
Skib Posted May 6, 2010 Report Share Posted May 6, 2010 I got rid of mine but I noticed when I pull the cap off there is a lot of suction . There is so much suction te tank makes a thump nois when you pull the cap off on some of the Z's if you take the evap tank out of the back the tanks will collapse. Quote Link to comment
DISLEXICDIME Posted May 6, 2010 Author Report Share Posted May 6, 2010 yah i am just putting it back Quote Link to comment
Docsis510 Posted May 6, 2010 Report Share Posted May 6, 2010 when you remove the vent line your tank can suck its self in and crack. Quote Link to comment
Creepy Cruiser Posted May 6, 2010 Report Share Posted May 6, 2010 When I did mine, I just cleaned it up and put it back in with all new lines. Quote Link to comment
DISLEXICDIME Posted May 6, 2010 Author Report Share Posted May 6, 2010 and its back in. So do the 68/69 have a vented cap? Quote Link to comment
Creepy Cruiser Posted May 7, 2010 Report Share Posted May 7, 2010 My 69 didn't have a vented cap, it just had a 1/4" hose that vented out the top of the tank and went through the floor and dumped under the car, lol. That's why I put a 71 evap can back there. Quote Link to comment
DISLEXICDIME Posted May 7, 2010 Author Report Share Posted May 7, 2010 Now I just need to figure out where to put the vent line from the evap can Quote Link to comment
