inline4 Posted March 30, 2010 Report Share Posted March 30, 2010 since I messed something up with the other one. now I have to figure out where to put things so I can tidy it up. should I mount everything against the firewall or against the kickpanel? Quote Link to comment
I'm BLUE Posted March 30, 2010 Report Share Posted March 30, 2010 since I messed something up with the other one. now I have to figure out where to put things so I can tidy it up. should I mount everything against the firewall or against the kickpanel? Firewall or wherever it was factory , if you were to sell it and I was looking I want a clean tape up or loom job , and everything about or very close where it was suppose to go for diagnostics purposes , and re-sell value. Otherwords it would be an issue for me , but you can make it look cleaner than factory to ;) . Firewall is my vote Quote Link to comment
inline4 Posted March 30, 2010 Author Report Share Posted March 30, 2010 the only problem with the firewall is that I have a hole in the upper left where the harness comes through, and the harness is really long. Quote Link to comment
bonvo Posted April 8, 2010 Report Share Posted April 8, 2010 decide where you wanna put the ecu then shorten the harness to give you the cleanest look Quote Link to comment
izzo Posted April 8, 2010 Report Share Posted April 8, 2010 my god man, get that black tape off that yellow wire first! Zip tie the wires up. Or shorten them. I like having extra length and zip tie them in case i need to cut, move or w/e later. Quote Link to comment
INDY510 Posted April 8, 2010 Report Share Posted April 8, 2010 I was going to say how clean the wiring looks......... what's wrong with where it is now? Don't make me go take a pic of my passenger floor pan................... it makes your wiring look alot better Quote Link to comment
73dime Posted April 9, 2010 Report Share Posted April 9, 2010 I would relocate the part of the harness that loops in and out of those two holes where the kick panel goes. With all the vibrating that the 510 makes, it may slowly cut your wires. If you feel around there you will notice it is kind of sharp. When I had similar situations I would buy some rubber trim and wrap the sharp part of the hole. Or you could just reroute it a different way. Do what you feel is best. Quote Link to comment
nukeday Posted April 9, 2010 Report Share Posted April 9, 2010 I've used a piece of split vacuum line to line holes cut in the body, even if they are factory. Just slice it the long way and put a little trim adhesive on it. Stays put and works well for larger holes. Quote Link to comment
inline4 Posted April 9, 2010 Author Report Share Posted April 9, 2010 decide where you wanna put the ecu then shorten the harness to give you the cleanest look thats what got me in this mess in the first place. I did a bad job :o I'm gonna take apart the old harness and re route things in the engine bay to tuck it. Quote Link to comment
inline4 Posted April 9, 2010 Author Report Share Posted April 9, 2010 I would relocate the part of the harness that loops in and out of those two holes where the kick panel goes. With all the vibrating that the 510 makes, it may slowly cut your wires. If you feel around there you will notice it is kind of sharp. When I had similar situations I would buy some rubber trim and wrap the sharp part of the hole. Or you could just reroute it a different way. Do what you feel is best. thats temporary. its wrapped in some tape and i dont think it will fray. Quote Link to comment
bonvo Posted April 10, 2010 Report Share Posted April 10, 2010 thats what got me in this mess in the first place. I did a bad job :o I'm gonna take apart the old harness and re route things in the engine bay to tuck it. you do one wire at a time and SOLDER AND HEATSHRINK EVERYTHING tell you what you bring me 200 bucks and buy the supplies and ill do a clean wire tuck for ya im not A.S.E. certified in electrical for nothin :P Quote Link to comment
inline4 Posted April 10, 2010 Author Report Share Posted April 10, 2010 you do one wire at a time and SOLDER AND HEATSHRINK EVERYTHING tell you what you bring me 200 bucks and buy the supplies and ill do a clean wire tuck for ya im not A.S.E. certified in electrical for nothin :P nah, I can handle it... its already out of the car. the only thing I didnt like doing was cutting the gray wires that had some grounding wire mesh thing and shortening those. Quote Link to comment
