Fuelrags Posted March 16, 2010 Report Share Posted March 16, 2010 Hey Guys, I plan on upgrading my Exhaust on my 83' 720 Z24 motor. What size should I run with the stock carb and exhaust manifold. I also "hollowed out" the catalyst for more exhaust flow,so should I go 2 or 2.25??? What are you guys running? Thanks,Martin Quote Link to comment
sssr20det510 Posted March 16, 2010 Report Share Posted March 16, 2010 Depends on what motor???? Quote Link to comment
Fuelrags Posted March 16, 2010 Author Report Share Posted March 16, 2010 Depends on what motor???? OOOPS! it's the Z24..... Quote Link to comment
Braden Posted March 16, 2010 Report Share Posted March 16, 2010 im running 2 inch on my l20b, it flows fine Quote Link to comment
datzenmike Posted March 16, 2010 Report Share Posted March 16, 2010 I think the stock Z24 IS a 2" down pipe. Stay with stock. You motor will not likely see 5,000 plus RPMs anyway. If it does it isn't making much to need a big pipe. Two inch will give best flow speed at highway speeds. Quote Link to comment
racerx Posted March 16, 2010 Report Share Posted March 16, 2010 2" is fine, 2.25 is okay and more than that you actually hurt performance. BTW what kind of muffler are you installing? Quote Link to comment
datsunfish Posted March 16, 2010 Report Share Posted March 16, 2010 Most people say 2" with most 4 cylinder motors but I prefer 2 1/4". I have 2 1/4" on my L16 in my 521 and it runs great. Just as much power as it would have with any exhaust but its fully ported too. 2" on my l20b in my 510 and I think it would make power a little longer with 2 1/4". 2" would be good for your z24 but 2 1/4 would sound cooler and better high end power. Buy a nice muffler too. Borla or Magnaflow straight through all the way for me. A high quality turbo muffler would be best for a z24 though probably. Quote Link to comment
elmerfudpucker Posted March 16, 2010 Report Share Posted March 16, 2010 My CAT fell the hell off! :lol: No clue why...Maybe the sawzall had something to do with it B) But anyhow I got 2" from the exhaust manni back to a magnaflow muffler, no complaints, good pull, mostly quiet unless I get on it. :thumbup: Quote Link to comment
Fuelrags Posted March 16, 2010 Author Report Share Posted March 16, 2010 2" is fine, 2.25 is okay and more than that you actually hurt performance. BTW what kind of muffler are you installing? I plan on setting it up old school style;NO catalyst with straight pipe all the way to the rear with a Thrush Turbo Muffler mounted behind the valance with a turn down tip. That's the way we did it in the late 80's. It sounds Bitchin' that way and runs alot better then the muffler mounted before the rear axle with a tail pipe...IMO Quote Link to comment
fo0manchu Posted March 16, 2010 Report Share Posted March 16, 2010 I had a 3" pipe turned down before my axles on my turbo ka, and that thing was way toooooo loud! But sounded fricken saweet. I say 2" would be ideal. 2.25" will give you room to free up more power if you do upgrade the carb or header Quote Link to comment
hang_510 Posted March 16, 2010 Report Share Posted March 16, 2010 on my LZ24 i went from 3" to 2.5" on a stock L mani. HUGE differance in the low/mid and MPG went up ~5mpg :o nothing noticable @ max rpm :mellow: Quote Link to comment
racerx Posted March 17, 2010 Report Share Posted March 17, 2010 Yep, just ordered a magnaflow for my 510 and have 2" exhaust...we'll see how it sounds. I had maganflow on my 75 Celica, sounded real good. I also heard that the dynomax super turbo sounds good. Quote Link to comment
racerx Posted March 17, 2010 Report Share Posted March 17, 2010 While we are talking about exhaust and I'm sure muffler will come up and I don't mean to hijack the thread but what kind of mufflers are you guys running? Quote Link to comment
elmerfudpucker Posted March 17, 2010 Report Share Posted March 17, 2010 While we are talking about exhaust and I'm sure muffler will come up and I don't mean to hijack the thread but what kind of mufflers are you guys running? Magnaflow Quote Link to comment
racerx Posted March 18, 2010 Report Share Posted March 18, 2010 just got magnaflow installed. 2.25 inlet and outlet. Sounds pretty good so far. Quote Link to comment
